what tranny is good for my engine?
Old Jan 16, 2006 | 08:25 PM
hakkoo's Avatar
Default what tranny is good for my engine?
i have d16z8 thinking about changing my tranny, ne suggestions on wat to get?
Old Jan 16, 2006 | 08:30 PM
1dumbscreenname's Avatar
Default Re: what tranny is good for my engine? (hakkoo)
you will be getting flamed soon so just run a search.
Old Jan 16, 2006 | 08:41 PM
DestructoEH's Avatar
Are you sure you don't have a d16z6 (sohc vtec)? if you're looking for a good tranny to go with whatever d-series motor you have, your best bet is a 92-95 Civic EX/Si tranny (s20). You can use your current axles, etc with this or any other d-series tranny. You can also opt for the 96-99 EX tranny (s40) because it has steel shift forks. Basically you can distinguish the EX/Si trannies by doing as so: near the drain plug on the tranny you will find these codes stamped on the case.
A000 = small bearing case CX/DX/LX = long gears
B000 = large bearing case EX/Si = short gears
Mista Bone did a write up on this in full detail. Next time try using search, it's been covered a million times. Good luck.
s1ngleslam
Oct 28, 2008 10:29 AM
slix_eg_
Aug 23, 2007 10:48 PM
Terrible One
Jul 10, 2005 10:50 PM
Purple_Civic
Jun 17, 2005 07:10 AM
J T*
Jan 11, 2002 03:45 AM
