Problem with vtec, no CEL--help?
Old Jan 16, 2006 | 07:56 PM
Stiz24's Avatar
Default Problem with vtec, no CEL--help?
Here's the deal: When my car warms up, I'll give it a go in first and second gear, and vtec works fine--it pulls as hard as it should and doesn't "bog" or anything out of the ordinary. After those two instances, vtec will no longer work. If I shut the car off and let it sit for, say, fifteen minutes or more, turn it back on, and take it for a drive, then it does the same thing--vtec twice, and no more afterwards. The ECU is NOT throwing a code, so I don't even know where to begin diagnosing something of this sort.
Any help would be greatly appreciated. I did a search for scenarios where vtec won't work, but I am only getting threads that involve the CEL coming on and that's not my particular problem.
Thanks!
Oh, it's obd-1 b16, I'd assume that shouldn't matter, but dang I suppose I'm desperate.
Old Jan 16, 2006 | 08:13 PM
pennies_hatchie's Avatar
Default Re: Problem with vtec, no CEL--help? (Stiz24)
there could be a few things wrong, i would check into oil pressure, maybe theres enough for the first few pulls and then not enough cutting vtec off
Old Jan 16, 2006 | 08:15 PM
Stiz24's Avatar
Default Re: Problem with vtec, no CEL--help? (pennies_hatchie)
good call, I actually just replaced my valve cover so that seems like the most reasonable explanation.
CTR_B
Mar 20, 2008 10:21 PM
Fastwhip
Aug 2, 2007 03:58 PM
mister_ej1
May 23, 2007 09:40 PM
bigdonnyboi
May 15, 2007 03:44 PM
allmotor94hatch
Aug 30, 2005 06:34 AM
