Civic Si rims on Accord?
Yesterday when I was standing around dumping $30 in my gas tank, a 90/91 Accord caught my eye....99/00 Civic Si rims on the back (steelies in front).
I though they were 4x100?...had'em on my 92 Civic and my 89 CRX.
Is there a similar set of rims to the 99/00 Civic Si wheel avalible for the 90/93 Accord?
to my knowledge, there is not...the closest thing would either be the 5th gen ex wheels or the 2000+ se wheels...other than that, there aren't really any stlyistically similar 4x114.3 wheels made by honda...it was more than likely a cheap ebay adapter he was using...either that, or the wheels were redrilled to 4 x 114.3
Check this out:
Honda Accord 1982-1989 (4x100mm / HPO / 12x1.5 Lug nut / 56.10mm Bore)
Honda Accord 1990-1997 (4x114.3mm / HPO / 12x1.5 Lug-nut / 64.10mm Bore)
Honda Accord 4-cyl 1998-up (4x114.3mm / HPO / 12x1.5 Lug-nut / 64.10mm Bore)
Honda Accord 6-cyl 1998-up (5x114.3mm / HPO / 12x1.5 Lug-nut . 64.10mm Bore)
Honda Civic 80-2002-up (4x100mm / HPO / 12x1.5 Lug-nut / 56.10mm Bore)
Honda CRV 1998-up (5x114.3mm / HPO / 12x1.5 Lug-nut)
Honda CRX 1982-1993 (4x100mm / HPO / 12x1.5 Lug-nut / 56.10mm Bore)
Honda Prelude 1982-1991 (4x100mm / HPO / 12x1.5 Lug-nut / 56.10mm Bore)
Honda Prelude 1992-1996 (4x114.3mm / HPO / 12x1.5 Lug-nut / 64.10mm Bore)
Honda Prelude 1997-up (5x114.3mm / HPO / 12x1.5 Lug-nut / 64.10mm Bore)
My references make note the Civics were available with 14 and 15" rims as was the 90 -93 Accords.
They may have been of a similar design, but all references still have the Civics with a 4x100mm bolt pattern, and the Accords with 4x114.3mm bolt patterns starting in the 1990 model year.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly »</TD></TR><TR><TD CLASS="quote">they were 2000 accord se or the prelude si rims.</TD></TR></TABLE>
se sedan for 4cylinder 6th gen(more tapered end, machined finish)
or
Si prelude 4th gen(more tapered end, less spokes and painted finish)
or
civic7gen
Nov 26, 2002 05:07 AM
