civic is doin' some messed up stuff? can anyone help?
Old Mar 21, 2002 | 10:47 AM
exr_pd's Avatar
Default civic is doin' some messed up stuff? can anyone help?
a'ight so here's the story. when i take my 89 civic dx mostly stock(intake and exhaust only) and hold the rpm for more than 3000rpm for longer than 1min i get a check engine light. cars still runs fine though and when i turn off the car and start it again its fine. the ecu says code 1 which is 02 sensor but i just replaced it. i also thought maybe it was fuel pressure so i got a new fuel filter . fuel injector diagnostic that i got from honda checked out to. new plugs and good compression.
decent gas mileage too. everything is great except for this.
pretty whacked out heh?
Old Mar 21, 2002 | 10:49 AM
MIDNIGHT's Avatar
Default Re: civic is doin' some messed up stuff? can anyone help? (civictype4)
do you have a header on it? and if so where is the o2 sensor mounted at?
Old Mar 21, 2002 | 10:54 AM
exr_pd's Avatar
Default Re: civic is doin' some messed up stuff? can anyone help? (MIDNIGHT)
no header just stock. and the o2 sensor is straight from honda to if that matters
(i heard some aftermarket o2sensors screw up the ecu)
Old Mar 21, 2002 | 12:08 PM
1RMDave's Avatar
Could be a problem with your ecu. Try reseting it..... I'm assuming you know how. But if you don't know how, just take the negative terminal off your battery for a few minutes and then reconnect it, start your car and let it run for a while, then turn it off and start it again. There you go, your computer is reset.
Old Mar 21, 2002 | 03:37 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Default Re: civic is doin' some messed up stuff? can anyone help? (OneStunna)
Had the same problem in my car and I reseted my computer now the check engine light doesnt turn on no more, try what Onestunna recommended
Clarkscivic802
Honda Civic (2001 - 2005)
20
Sep 20, 2016 09:12 PM
Ericreid317em1
Oct 14, 2013 11:02 AM
utn
Oct 1, 2009 02:16 PM
x91crxsix
May 20, 2008 09:04 AM
Street Inc
Jul 25, 2005 12:14 PM
