no tach... how fast per gear?
Old Jan 16, 2006 | 03:41 PM
92hatch420's Avatar
Default no tach... how fast per gear?
i dont have a tach and just got my d16z6 was curious how fast i should be goin in each gear. have a cx d15 tranny
holla back
Old Jan 16, 2006 | 03:57 PM
JCritt's Avatar
Default Re: no tach... how fast per gear? (92hatch420)
whenever ur engine sounds like its about to explode
Old Jan 16, 2006 | 03:58 PM
Lewy. Dee Ayy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatch420 &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a tach and just got my d16z6 was curious how fast i should be goin in each gear. have a cx d15 tranny
holla back </TD></TR></TABLE>
i have a stock 95 cx..1st gear..i change around 15-20...then..so on and so forth..pretty much 10-15 mph between gears..
accept..4-5th. can go from..35 to 70mph in 4th..and..havent gone faster then that..and dont like to use 5th..the gear is chipped or somthing..it bumps wen i go into 5th..and its hella loud..
Old Jan 16, 2006 | 04:29 PM
92hatch420's Avatar
i aint got a license right now so i havent really got to drive it took it out for a little bit the other day only made it into 3rd 1st gear i took to 30 2nd to 60 and 3rd i didnt really get on it. aint tryin to get busted for no license again.. couple more days tho and ill have them back suspension is up for the 3rd time. anyway sounds like i was pretty close, didnt sound like anything was gonna blow. i noticed when i shifted to 2nd it kinda bogged a little tho, didnt get up and go like 1st.
thanks
Old Jan 16, 2006 | 04:40 PM
JCritt's Avatar
dude just go like this
0-20 1st
20-30 2nd
30-40 3rd
40-60 4th
60+ 5th
Those shifts are at about 3,200 rpm or so.
Old Jan 16, 2006 | 04:46 PM
robert_v's Avatar
if you are trying to max out each gear, take third to 110mph that should be redline. for ex/si tranny, i only managed 90 mph on third. get an ex/si tranny it makes your z6 run way faster
Old Jan 16, 2006 | 10:26 PM
b16hybridsol's Avatar
Default Re: (robert_v)
general rule of thumb is 30mph per gear to redline
Old Jan 16, 2006 | 11:35 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (b16hybridsol)
actually thats not a bad rule of thumb. pretty close to mine at 36.72.96.128.174
Why they geared it to go 174mph i have no idea, it wont break 120. but thanks for the good mpg in FIF!!!!
Old Jan 16, 2006 | 11:40 PM
teamvirus's Avatar
My car breaks a lot!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khaa &raquo;</TD></TR><TR><TD CLASS="quote">whenever ur engine sounds like its about to explode </TD></TR></TABLE>
hahah
Old Jan 16, 2006 | 11:42 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">general rule of thumb is 30mph per gear to redline</TD></TR></TABLE>
correct (but not on my tranny )<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">actually thats not a bad rule of thumb. pretty close to mine at 36.72.96.128.174
Why they geared it to go 174mph i have no idea, it wont break 120. but thanks for the good mpg in FIF!!!!</TD></TR></TABLE>
even though your car is geared so that it "could" go up to 174mph, the only reason for this is give it good cruising rpms. general rule of thumb, your cruising at 70mph tends to be near half of your redline
Old Jan 18, 2006 | 05:04 PM
DB1_559's Avatar
o-32 1st gear
32-70 2nd
70-92 3rd
92-110 4th
110-max 5th and this is to redline
Old Jan 18, 2006 | 05:32 PM
Bense's Avatar
Default Re: no tach... how fast per gear? (jdmboi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">o-32 1st gear
32-70 2nd
70-92 3rd
92-110 4th
110-max 5th and this is to redline </TD></TR></TABLE>
uh what? wrong tranny dude.
Old Jan 18, 2006 | 06:03 PM
DB1_559's Avatar
not really dude i tested this before with my cx and my si so its about rite
Old Jan 18, 2006 | 06:50 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">not really dude i tested this before with my cx and my si so its about rite </TD></TR></TABLE>
cx with stock wheels and a 7200rpm redline = 85mph at the end of second
cx tranny
1st = 3.25
2nd = 1.762
3rd = 1.066
4th = 0.853
5th = 0.702
final = 3.25
i have taken mine apart and literally counted the teeth
Old Jan 18, 2006 | 06:53 PM
Bense's Avatar
Default Re: no tach... how fast per gear? (Bense)
to the original poster. if you're running the stock wheels, 7200rpm redline, and a cx tranny your gears end at the following mph
1st = 46
2nd = 85
3rd = 140
4th = 175
5th = 213
my zc 3rd with my ex 4.25 final drive ends at 85mph at 7200rpm.
Old Jan 18, 2006 | 09:38 PM
DB1_559's Avatar
ok then whateva
Old Jan 18, 2006 | 11:09 PM
pratt93si's Avatar
my 93 si hatch
0-30ish
30-59
60-90
4th gear to 110 then 5th to 114 and the engine wont let it go past 114.
crazyhouse2011
Jul 22, 2013 07:55 PM
ej1252
Sep 18, 2008 09:23 PM
EG type GTR
Jul 22, 2006 12:58 PM
99sibluehatchwitb16
Jan 18, 2006 08:43 PM
superls92
Oct 4, 2003 11:54 PM
