Looking for an article on Sound Deadening
Old Jan 16, 2006 | 02:36 PM
superthug's Avatar
Default Looking for an article on Sound Deadening
I went through all the threads on sound deadening. Someone had posted a very good article on sound deadening in a thread. It discussed the different types of products and the results. Please post it if you have it bookmarked.
Thanks.
Old Jan 16, 2006 | 06:03 PM
TurboLaxx's Avatar
Default Re: Looking for an article on Sound Deadening (superthug)
This is all i could find.
https://honda-tech.com/zerothread?id=1026673
I did a little write up on sound deadening my car awhile ago:
http://www.cardomain.com/ride/813664
This guy did a very clean job on his honda
http://www.cardomain.com/ride/496797
Old Jan 16, 2006 | 07:06 PM
EBP_SI's Avatar
Default Re: Looking for an article on Sound Deadening (TurboLaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLaxx &raquo;</TD></TR><TR><TD CLASS="quote">This guy did a very clean job on his honda
http://www.cardomain.com/ride/496797 </TD></TR></TABLE>
and an even cleaner job on his M3. btw...thats Rcurley55 from this site
Old Jan 16, 2006 | 07:36 PM
superthug's Avatar
Default Re: Looking for an article on Sound Deadening (EBP_SI)
TurboLaxx, I really liked your setup and your write-up was very well done.
I had the same idea in mind about the floorboard. Did you screw down the right and left sides toward the front? I guess you did it so the floorboard doesn't move.
Did the peal and seal make a difference as far as reducing noise? How much of it did you use?
Old Jan 16, 2006 | 07:51 PM
superthug's Avatar
found the article
http://www.sounddeadenershowdown.com/
Old Jan 16, 2006 | 07:57 PM
TurboLaxx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superthug &raquo;</TD></TR><TR><TD CLASS="quote">Did you screw down the right and left sides toward the front?
Did the peal and seal make a difference as far as reducing noise? How much of it did you use?</TD></TR></TABLE>
Yeah i screwed down every panel..you can see some screwed in this picture:
Well i think the peal and seal really just keeps the sound "in" the car. I can turn my sound up LOUD and then stand outside with the doors closed. You would never believe how loud it is inside from what you hear outside. I'm guessing it cuts down the sound by 2/3's. So i'm guessing it keeps out 2/3's of the outside noise into the car. I would really need some type of sound meter to justify the sound reduction.
The only thing i would change is how much Peal & Seal i put down. I bought a 18"x34' roll for $35 at a local roofing supply. I should have bought the 36"x34' roll. That way out could have lined the floor with peal & seal and the thermozite. I ran out of Peal & seal at the end because of all i used in the trunk. Ifyou dont care about added weight and you want to roll like a lexus...get the larger roll of peal and seal (if doing trunk and cabin) and put the thermozite all over.
Old May 6, 2006 | 04:31 AM
Cole D's Avatar
Where did you buy Thermozite at ?
TIA
Old May 6, 2006 | 02:51 PM
Cole D's Avatar
Default Re: Looking for an article on Sound Deadening (Cole D)
Found it Thanks
Old May 7, 2006 | 11:11 AM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">and an even cleaner job on his M3. btw...thats Rcurley55 from this site</TD></TR></TABLE>
thanks guys...the m3 comes back from the shop on monday or tuesday - back to work on yet another install - this will be the third in that car in a year - yikes.
Old May 7, 2006 | 11:54 AM
EBP_SI's Avatar
Default Re: Looking for an article on Sound Deadening (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks guys...the m3 comes back from the shop on monday or tuesday - back to work on yet another install - this will be the third in that car in a year - yikes.</TD></TR></TABLE>
why dont you just settle for mediocre sound quality?
Old May 7, 2006 | 08:15 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just settle for mediocre sound quality? </TD></TR></TABLE>
you know that's impossible
Old May 8, 2006 | 01:18 PM
EBP_SI's Avatar
you know that's impossible </TD></TR></TABLE>
so exactly what will your new setup be?
Old May 8, 2006 | 04:45 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">so exactly what will your new setup be?</TD></TR></TABLE>
nice thread jack
Looking at the following:
Source: factory bmw or W200 + iPod
Amps: Zapco DC650.6 and DC750.2
Front: DLS Ultimate Iridium 6.3
Subs: 2 x ID10v3
So, all the processing is done by the amplifiers in the digital domain. Balanced outs from the headunit can be used by the zapco, or I have BLT's if I go with the Alpine. Subs sealed in a fiberglass box in the corner of the trunk, midbasses ib in the doors, midranges in the kicks - the only question is tweeters in kicks or a-pillars.
So, pretty similar to the older setup - I got away from the horns - with some better positioning of the speakers and a little more power total. Also making things more simple with the zapco amps, rather then external processor.
All in all, I've alredy got the speaker locations worked out, and she stages and images really great. Just a matter of building it better then last time.
daddy
Audio / Security / Video
Dec 4, 2007 04:41 AM
RR98ITR
11
Oct 27, 2005 04:19 PM
Civic321
Sep 6, 2004 08:08 PM
'05 SubyD
May 13, 2004 10:30 AM
