clutch cable a little long?and....
Old Jan 16, 2006 | 02:18 PM
rewerbcrx's Avatar
Default clutch cable a little long?and....
i was wondering if i was suposed to change my clutch cable... when i did my swap 91 CRX HF with a b18a1 in her... also ..i need a bracket for my throttle cable... there wasn't one on the block... any ideas?
Old Jan 16, 2006 | 02:23 PM
rewerbcrx's Avatar
Default Re: clutch cable a little long?and.... (rewerbcrx)
should i run the clutch cable behind the engine instead of on top? i am not near my garage so i can't try it right not
Old Jan 16, 2006 | 02:34 PM
EKIM NART's Avatar
i used a 90-93 integra clutch cable when i swapped a ls-vtec into my hatch i would think it would be the same for a crx
Old Jan 16, 2006 | 02:39 PM
W O T's Avatar
Default Re: clutch cable a little long?and.... (N ef A)
just make a bracket like I did
make the cables route longer
Old Jan 17, 2006 | 08:11 AM
rewerbcrx's Avatar
Default Re: clutch cable a little long?and.... (W O T)
do i need a bracket for my throttle cable and where could i get one
Old Jan 17, 2006 | 09:56 AM
jdeemseerx's Avatar
i would hope that there wouldnt be a bracket for your throttle cable on the block per say but yes you do need one..pick one up from a junkyard,, ive seen plenty of ppl use their stock cable on ls motors so i dont bleieve you have to change it
kricket3000
Sep 15, 2009 11:44 AM
madgeo
Jul 22, 2009 03:41 PM
Its me DUB
Jan 29, 2007 12:03 PM
Zubi
18
Sep 17, 2006 11:10 PM
13secondcivic
Feb 17, 2002 06:38 PM
