4th gen SE spindle nut size?
All it says in the manual for the spindle nut size is 24x1.5 which is the thread pattern. What size socket do I need to get it off? 32mm is too small. TIA
If you're talking about the rear - definately 32mm.
If you go to napa or something, they'll try to give you a 36 mm - that is incorrect. I have a socket if you need it(32mm).
How is 32mm too small?.........i guess you can try 36mm. Its somewhere between there. Mine was 32mm - I used a 12pt socket to get it off.
Were we talking about the front or the rear?
They do have two sizes - i checked with the dealership. They said they have two different part numbers - one is 36mm and the other is 32mm. Mine on my rears are 32mm - just changed my hubs.
EliteCivicX
Suspension & Brakes
Feb 18, 2005 09:15 AM
