cutting aluminum sheet
Old Jan 16, 2006 | 12:11 AM
@irborne's Avatar
Default cutting aluminum sheet
what do you guys use to cut aluminum sheet up to 1/4"???
Old Jan 16, 2006 | 12:25 AM
k24em2's Avatar
Default Re: cutting aluminum sheet (@irborne)
Plasma cutter.
Old Jan 16, 2006 | 06:02 AM
Zornig's Avatar
Default Re: cutting aluminum sheet (k24em2)
I also use plasma but you could use a jig saw.
Old Jan 16, 2006 | 07:42 AM
@irborne's Avatar
i could imagine jig saw would take forever
Old Jan 16, 2006 | 07:51 AM
dfoxengr's Avatar
Default Re: (@irborne)
not with a decent blade.
al is much softer than steel.
Old Jan 16, 2006 | 08:17 AM
splitime's Avatar
Default Re: (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">not with a decent blade.
al is much softer than steel.</TD></TR></TABLE>
Fills up the teeth with aluminum though, only downside of cutting it.
Old Jan 16, 2006 | 08:24 AM
dfoxengr's Avatar
Default Re: (splitime)
4.5 angle grinder wouldnt clog too. theres another option
Old Jan 16, 2006 | 09:12 AM
hybridmoments's Avatar
i've used a jig saw on 1/4 " alum when i didn't have access to plasma
it's not too slow. just use a good blade designed for metal. also, i used some tapping fluid while cutting. helped keep the blade clean, cool, and definitely went alot faster.
Old Jan 16, 2006 | 10:15 AM
Zornig's Avatar
Default Re: cutting aluminum sheet (hybridmoments)
Yes when using a jig you will need some type of lube to keep the teeth from cloging up.
You can also use a grinder with the correct wheel. Yes they make wheels just for cutting aluminum.
Old Jan 16, 2006 | 10:22 AM
weiRtech's Avatar
OG Fabricator
you could probably spray the jig saw blade with some wd40 as you cut along to help keep it from getting gummed up.
Old Jan 16, 2006 | 10:31 AM
Zornig's Avatar
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">you could probably spray the jig saw blade with some wd40 as you cut along to help keep it from getting gummed up.</TD></TR></TABLE>
yup works like a charm just makes a mess.
Old Jan 16, 2006 | 01:21 PM
BigMoose's Avatar
I use a 7 1/4 inch circular saw, like a skill saw, with a negative rake angle carbide blade designed for non ferrous metals. Works like a champ. Wear goggles for sure. Remember you have to have the right blade. I paid over $100 for my blade.
Learned this trick from my brother in law, who had a summer job working at a large name brand aluminum truck dump body manufacturer.
Old Jan 16, 2006 | 01:27 PM
KFMRC's Avatar
I agree with big moose a 7 1/4 circular saw kicks *** it will cut up to 1" thick with a little lubrication I use wd40 or crc power lube I usually use a regular 60 tooth caride blade but I do know that the correct triple chip carbide blade will work even better
it takes a sharper blade to cut wood than aluminum 1/4 "will cut as easy as a 2x4
be careful to make sure the blade doesn't get pinched it will kick back
been using a circular saw since the late 70's early 80's it works
Old Jan 16, 2006 | 01:45 PM
dk-fabrications's Avatar
Default Re: (KFMRC)
you can a angle grinder which works well but also a jig saw works good but make sure you keep the blade free from the chips by using wd40 or another lubricant
good luck with it
Old Jan 29, 2006 | 09:53 PM
@irborne's Avatar
angle grinder takes too damn long on thicker pieces....looks like a plasma cutter in the list.
RJ#9
Welding / Fabrication
Jan 19, 2009 06:18 PM
NACvicSi
Oct 14, 2007 10:49 AM
HT Chaplain
31
Aug 7, 2007 06:41 AM
rice a roni
Sep 7, 2004 09:57 AM
92BlackSi
Audio / Security / Video
Apr 21, 2004 01:59 PM
