Wheel balance needed?????
A few weeks ago I noticed some unfamiliar road noise traveling on the highway. It sounds like a faint WAWAWAWAWAWA traveling at speeds of 40 and up. The car has no pull to either side so I don't think it's the alignment. Would you recommend taking the wheels in for rebalancing? I'm riding on the stockers with Kumho 712's.
Any advice???
TIA,
Chris
Any advice???
TIA,
Chris
balance shouldnt cause a noise, it causes a vibration...
the noise you are hearing is prolly your tires being cupped...
I would take a look at them and see if they are wearing smoothly
I did check the tires and they seem to be wearing evenly. I do rotate often. If not a wheel balance problem, what else might it be? Something suspension related?
Chris
Chris
hmm..
posibly a bearing?
a bearing is easy to check for...
drive along where it is making the noise...
swerve left, then swerve right...
if it is a bearing, the noise will not be present when you turn in 1 of the directions
(unless both are bad)
posibly a bearing?
bambbrose
Oct 11, 2015 08:01 AM
tunes12
12
Aug 28, 2007 04:54 PM
batboyvaj
Mar 16, 2003 06:25 AM
