How could I make my instrument cluster light brighter?
Old Jan 15, 2006 | 09:01 PM
xkrntamax's Avatar
Default How could I make my instrument cluster light brighter?
I changed my instrument cluster light bulb inside.
I changed to Red Color.
One I changed is not that bright.
I can only see the light when it's get dark.
I want to make more brighter so I can see the light on anytime.
I saw some people changed the instrument light bulb and their bulb was very bright.
Give me any suggestion.
Old Jan 18, 2006 | 06:54 AM
xkrntamax's Avatar
Default Re: How could I make my instrument cluster light brighter? (xkrntamax)
anyone know about this???
Old Jan 18, 2006 | 07:13 AM
rdblckSV650S's Avatar
is it LED or an incandescent bulb?
Is it a dark red or a light red??
Dark red is going to be dark no matter what, and you can't really control that. If you bought an omnidirectional LED 194 bulb it might be brigther, but i can't make any promises.
Old Jan 18, 2006 | 07:44 AM
DC2TEGGA-GSR's Avatar
did you buy a red bulb or did you color it with a marker or spraypaint??? i hope you bought the bulb, i know a couple of people who have gone with spraypaint and markers, that is so ghetto, make sure your cluster light adjustment is turned all the way up (counter clockwise) becuase that is comonly overlooked
Old Jan 18, 2006 | 09:36 AM
xkrntamax's Avatar
Default Re: How could I make my instrument cluster light brighter? (DC2TEGGA-GSR)
I bought the bulb.
and I turned all the way up.
I will try to use LED. If not work what i want.
then that's sucks. haha
Old Jan 18, 2006 | 10:38 AM
mystikalstriker's Avatar
get the led's with the largest range of output, since led's are traditionally bright but narrow with light output. But even with that you still can't expect it to be that bright to see it all the time. For that you might want to try getting indiglo gauges since they seem to emit light through them more
Old Jan 18, 2006 | 10:41 AM
stillrockin18s's Avatar
What year teg? On the 90-93 Integras if you look up at the top of the cluster you can see lights that has a blue cover on and it shines down on the cluster, if you remove that blue cover you will increase your light up there by about 50%, not sure about the 94+ Integras though, because I think all the instrument lights are in back of the cluster.
Hope this helps, good luck.
Old Jan 18, 2006 | 11:31 AM
xkrntamax's Avatar
Default Re: How could I make my instrument cluster light brighter? (mystikalstriker)
where can i get indiglo gauges?
oh before i changed my 194 bulb.
The stock bulb has blue vinyl on it.
Anyway I changed to the Red 194 bulb.
I want my instrument cluster like New nissan Altima.
I think because altima has cover each gauge, that's why it's kind of dark.
So when you put light on you can see that well.
Old Jan 18, 2006 | 11:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax &raquo;</TD></TR><TR><TD CLASS="quote">where can i get indiglo gauges?</TD></TR></TABLE>
ebay
Old Jan 18, 2006 | 12:26 PM
Default Re: How could I make my instrument cluster light brighter? (lowriden_acura)
Ok, you can buy indiglo guages anywhere that sells car stuff. You really shouldn't have to ask us where to buy car stuff.
The stock bulbs do have a blue condom on them, yes. Tha'ts what makes the light that comes out white.
I really didn't understand anything you said about the nissan altima.
If you want a nice deep red, it's gonna have to be LEDs.
I'd go to http://www.superbrightLEDs.com and look at their flat tipped wide dispersion 194 bulbs in red. My friend used them in his climate control on his evo and they came out great.
Old Jan 18, 2006 | 12:39 PM
xkrntamax's Avatar
Default Re: How could I make my instrument cluster light brighter? (slvrblckf4i)
forget about altima.
If you see new altima instrument cluster.
the light us very bright.
other question.
how could i change my climate control light bulb?
Old Jan 18, 2006 | 01:12 PM
DJ Gurgla GSR's Avatar
try wide angle LEDs (i think thats what they're called). bulb is kinda flat on top and has a little cone type thing on the inside which disperses the light better. tough to explain
you can find them on http://www.superbrightleds.com
Antony Stone
Honda Civic (2001 - 2005)
Apr 11, 2017 12:47 AM
junior_tm
May 6, 2008 08:02 PM
xkrntamax
Dec 12, 2005 08:14 PM
uneek4dr
Dec 20, 2002 07:55 AM
