Thinking about moding my sunroof, looking for info from people that have worked on them
Old Jan 15, 2006 | 06:47 PM
hughesl's Avatar
Default Thinking about moding my sunroof, looking for info from people that have worked on them
I am thinking about pulling the motor out and all of the hardware except the slide mechanism. I have a question for anyone that has messed with these before.
I would like to keep the sunroof, so I don't want to plug it. If I remove the "guts" could I slide it by hand when I wanted it open or shut? Anyone else do this?
Thanks.
Old Jan 15, 2006 | 07:13 PM
SD_Lurker's Avatar
HT White Ops
Default Re: Thinking about moding my sunroof, looking for info from people that have worked on them (hughesl
what would be your reasoning for doing this?? i hope that you dont say to take weight off your car.
Old Jan 15, 2006 | 07:15 PM
trrbl1bmx's Avatar
A kid near me molded his si.. he took the sunroof and all componets out ( which are heavier than you think. ) and he got a dx headliner and you can't even tell it was ever an si
Old Jan 15, 2006 | 07:22 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote">A kid near me molded his si.. he took the sunroof and all componets out ( which are heavier than you think. ) and he got a dx headliner and you can't even tell it was ever an si
whats the point of buying an Si then?? Thats one of the main things that sets it apart. If you dont want a sun roof then go buy a DX. Dont waist a perfectly good car and mold the sun roof. Hell, dont even listen to this guy.
Old Jan 16, 2006 | 04:06 AM
2ndGenREX's Avatar
i have a 90 crx si, i luv the sunroof but sometimes wish it was clear so i could see threw it.....anybody kno where i can order a clear sunroof to fit onto the sunroof frame ?
Old Jan 16, 2006 | 06:26 AM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">
whats the point of buying an Si then?? Thats one of the main things that sets it apart. If you dont want a sun roof then go buy a DX. Dont waist a perfectly good car and mold the sun roof. Hell, dont even listen to this guy.</TD></TR></TABLE>
if that's the reason you bought an si, then i'm pretty sure any argument i have here will be wasted, but...
drive a hf, a dx, and an si back to back in otherwise equal csp trim- then we can talk. and i'm pretty sure the first word you say won't be "sunroof".
the whole assembly weighs 33 lbs. and it's at the highest part of the car, making it great weight to save. i love the sunroof in my street crx (no ac makes it sort of necessay), but i'll never miss it again in my autox car.
to the original poster- you aren't going to save a lot, but if that's where you're comfortable, i won't try to sway you. i'm not sure your plan will work though, as it seems like there would be keeping everything in place, not to mention that i have no experience (does anyone?) trying to open the roof in any other way than the switch or the manual screw. is there anything left that would keep it from being a floppy and unusable mess?
Old Jan 16, 2006 | 10:08 AM
hughesl's Avatar
Thanks for the input.
I understand the comments.
If the track assembly is left intact and only the motor, cables are removed I don't think it will be floppy.
My biggest concern would be the answer to your other question.."could you function the sunroof without using the button?" That is the main information I am looking for now. I am sure someone has done maintanance on one of these and can answer that question. With that information I can make a number of decisions.
My worry is that it is not possible to cycle it.
Old Jan 16, 2006 | 10:26 AM
CRX Toad's Avatar
My question is how will you secure it from not sliding open under heavy acceleration or from having a theft come in through the roof?
Old Jan 16, 2006 | 05:43 PM
hughesl's Avatar
It probably would not open under heavy acceleration because you would have to push it up before it would go back.
As for theft, that would be a problem.
My car lives in my garage-work-autocross-and fun drives.
It is never left anywhere to get broken in to.
Anyone worked on these?
chaoshonda
17
Apr 17, 2007 02:34 PM
6speedMaster
Honda Civic (2006 - 2015)
19
Mar 21, 2006 09:32 AM
mellon
24
Sep 8, 2004 02:58 PM
eghatchomar
Sep 1, 2004 12:09 AM
I3ackfire
12
May 9, 2004 07:53 PM
