How to guides?
Old Jan 15, 2006 | 05:21 PM
Ruskimafia's Avatar
Default How to guides?
Any body have online how to guides on removing parts (door panels and other panels )
Im trying to replace my rear speakers so i was wonderning how to remove it
thanks
Old Jan 15, 2006 | 05:34 PM
i_kick_turtles's Avatar
Default Re: How to guides? (Ruskimafia)
Need more info on the car.
Old Jan 15, 2006 | 05:35 PM
RidnLow's Avatar
Well what year accord do you have? its quit easy all you do is take all the screws out which are located at the handle, one is at the very bottom and one on the side the the last one should be in the handle you use to shut the door with. then all you do after that is take everything off the panel then pop the panel off!
Old Jan 15, 2006 | 05:48 PM
Ruskimafia's Avatar
2000 accord v6 4 dr
6 speaker system
Old Jan 15, 2006 | 05:54 PM
iam7head's Avatar
Default Re: (Ruskimafia)
open your trunk and look up at the rear deck, this all there
Old Jan 15, 2006 | 06:00 PM
BLKFLSH's Avatar
If you plan on keeping the car for any length of time, get a cheap repair manual from Autozone or Advance. Or every time you have something that needs to be done you will have to spend time searching for how-to's. Just a suggestion.
Old Jan 15, 2006 | 06:23 PM
Ruskimafia's Avatar
good idea
i just wanted to know b/c i was wroking on a freinds 2000 civic installin subs and amps and the whole rear deck had to come off to get to rear speakers. i dont hink its liek that for my car i did te fromnt doors those were easy the back should be easy to
Thanks alot guys
whispergarden
Jan 18, 2012 10:56 AM
wagonator
May 30, 2011 07:03 AM
Importn2oRacer
Mar 9, 2007 03:51 PM
thinkandactACCORDingly
Audio / Security / Video
Feb 27, 2006 09:43 AM
Infadel
Aug 5, 2002 07:53 PM
