Climate control ?
Old Jan 15, 2006 | 02:25 PM
Got_soy's Avatar
Default Climate control ?
When I turn the fan on, it only comes on at positions 3 and 4. Do I need to get a new climate controll panel or is it a wireing problem
Old Jan 15, 2006 | 02:28 PM
Keebler's Avatar
Default Re: Climate control ? (Got_soy)
I would have to guess it would be your climate control. Too bad, cause I just sold a mint one.
Look around in the classifieds. If it were anything else, it wouldnt work at all, not just on the 3/4 selection.
Old Jan 15, 2006 | 02:41 PM
Got_soy's Avatar
Default Re: Climate control ? (Keebler)
yeah it suck 1&2 not working, it gets real hot fast
Old Jan 15, 2006 | 02:42 PM
Keebler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">yeah it suck 1&2 not working, it gets real hot fast</TD></TR></TABLE>
Best bet would be to check the classifieds section or ebay for a new CC. Good luck
Old Jan 15, 2006 | 02:47 PM
1989CivicSi's Avatar
before you put money into a new climate control, check the wiring/contacts. Bought a new sunroof motor a few weeks ago to find that the problem was buildup on my switch .
Old Jan 15, 2006 | 02:49 PM
Keebler's Avatar
Default Re: Climate control ? (1989CivicSi)
the CC is a sealed unit... how do you plan on checking it? More power to you if you can, but its 50 bucks or so for a new unit.
Old Jan 15, 2006 | 02:53 PM
downest's Avatar
Take it apart. I read a post about this a while back, maybe it was over on the resoure. There are resistors for 1-3, and none for #4, the contacts between the slide and the resistors gets worn out over time, if it gets really bad you would only have #4 fan setting. My #1 is gone right now and I plan on taking care of it soon, I can take pics if you like.
Old Jan 15, 2006 | 03:00 PM
si0385.'s Avatar
Default Re: Climate control ? (downest)
this is a very common problem in gm cars... the blower motor resistor burns up and only certain fan speeds will work 1-3 circuts go through the blower motor resistor but #4 (the high speed fan setting) runs an a separate circut so you might loose any one or all of speeds 1-3 but 4 will work....
check into the blower motor resistor when i was working as a gm tech in new york i did a million of them on gm cars and a hand full on Chrysler cars
Old Jan 15, 2006 | 03:38 PM
Got_soy's Avatar
Default Re: Climate control ? (jaydeum4lyfe)
so what do i need to look for?
Old Jan 15, 2006 | 04:01 PM
DieMaster's Avatar
Needs to be About 20% Cooler
take off your glove box. right behind it, nerrest the door is a white enclosure thats the blowwer. on top of it in front of the reculate inlet you'll see a 4 wire plug. thats the blower resister. take out the 2 screws holding it in and see if one of the resistors (tallest one if i remimber corectly) is busted. there are 3 resistors in it. if u look at the wire in the loops u can see there diffrent diamiters. if 3 works then the thickest one is intact but if 2 dosent then the scond bigest one isint intact. if only 1 didnt work it'd be the smallest diamiter one. anyway no need to even touch your CC panal. your weakest link is the blower resistor.
Mr_Si-R
11
Jun 7, 2006 12:21 PM
Kevedge
May 4, 2004 02:24 PM
B2FiNiTY
Sep 1, 2003 05:29 PM
SSA 1
12
Jul 18, 2003 01:03 PM
2k1_ITR_0736
Jun 19, 2003 02:00 PM
