cheanged my axles but car wont move!!!!
Old Jan 15, 2006 | 08:25 AM
veilsides2000's Avatar
Default cheanged my axles but car wont move!!!!
Okay as i stated above i changes my axles, both of them but when i put the car in gear and try to drive, it just revs up. It doesnt move or drive. I tried putting it in first a letting the clutch go and the car doesnt stall. i can even put the car into gear without pressing the clutch. is ther something i did wrong??? please explain. thanknyou
Old Jan 15, 2006 | 08:32 AM
Default Re: cheanged my axles but car wont move!!!! (veilsides2000)
ANYBODY?
Old Jan 15, 2006 | 08:47 AM
gsrboy171
Guest
Posts: n/a
check over what you did and make sure your axles snap in to place to your tranny.
Old Jan 15, 2006 | 08:57 AM
Default Re: (gsrboy171)
is there a way i can make sure that there in place the right way??
Old Jan 15, 2006 | 03:05 PM
1337whp's Avatar
well if you say that you can let the clutch out when in gear and it wont stall and/or if it "is in gear" and it only revs and doesnt not move its a high possability it is your clutch
Old Jan 15, 2006 | 03:08 PM
da6jdmteg's Avatar
Default Re: cheanged my axles but car wont move!!!! (1337whp)
sounds like clutch to me friend
Old Jan 15, 2006 | 03:14 PM
Rajin's Avatar
Default Re: cheanged my axles but car wont move!!!! (da6jdmteg)
Clutch
Old Jan 15, 2006 | 03:19 PM
mantegra's Avatar
are you sure you put the axles in all the way
Old Jan 15, 2006 | 05:10 PM
KeithsDAteg's Avatar
When it revs up, is it making a "clanking" sound??
Was your car pulling fine before you replaced you axles?
Need more details..
Old Jan 15, 2006 | 07:38 PM
3.504's Avatar
Default Re: cheanged my axles but car wont move!!!! (KeithsDAteg)
i'd say turn the wheels so you can see an axle (driver or passenger)
push the axle in all the way then pull on it to make sure it seated
turn the wheel the other way, go to the other side and do the same. now attempt to drive the car.
Old Jan 15, 2006 | 07:49 PM
bak lee's Avatar
Don't think your passenger side axle is in all the way.
Old Jan 15, 2006 | 08:44 PM
microsoft_sux's Avatar
You got an axel that isn't hooked up correctly. Happened to me once, was driving and the car stopped accelerating. RPM's were going up but it was like it was in neutral. Had to hitch a ride home and get a tow. Turns the bolts that hold axel in were loose.
Old Jan 15, 2006 | 08:51 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da6jdmteg &raquo;</TD></TR><TR><TD CLASS="quote">sounds like clutch to me friend</TD></TR></TABLE>
OMG What the hell are you people shooting up? Yeah....it's his clutch, which functioned immediately prior to his axle swap
Disassemble everything and reinstall correctly. Perhaps there was another thing you over looked? Completely redoing it would be a good piece of mind that everything is done properly.
Aquila
Jul 29, 2016 04:11 PM
OhBai
Jan 21, 2012 06:58 PM
Blaze45
14
Jul 28, 2003 08:26 PM
vtec69
14
Mar 29, 2003 12:20 AM
tooqwik1
Jul 14, 2002 03:26 AM
