JDM gsr to replace usdm?
Old Jan 15, 2006 | 07:29 AM
EJ8chu's Avatar
Default JDM gsr to replace usdm?
ok i blew up my USDM OBD-1 gsr motor in my 91 GS. Will a JDM OBD-1 gsr motor plug right up to my existing harness?
Old Jan 15, 2006 | 09:51 AM
IntegraLova's Avatar
Default Re: JDM gsr to replace usdm? (xxsteve803xx)
Are you sure that your usdm motor is toast? What happened?Perhaps you could do a rebuild?
Old Jan 15, 2006 | 11:23 AM
EJ8chu's Avatar
Default Re: JDM gsr to replace usdm? (IntegraLova)
well i just want a better motor anyways...BTW us block is for sale!
Old Jan 15, 2006 | 02:35 PM
EJ8chu's Avatar
bump cuz i need a straight up answer
Old Jan 15, 2006 | 03:32 PM
98 Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxsteve803xx &raquo;</TD></TR><TR><TD CLASS="quote">ok i blew up my USDM OBD-1 gsr motor in my 91 GS. Will a JDM OBD-1 gsr motor plug right up to my existing harness?</TD></TR></TABLE>
It will plug right in. They are basically the same setup, except the JDM GSR is 180 hp compared to the USDM GSR which is 170 hp.
Old Jan 16, 2006 | 04:43 PM
EJ8chu's Avatar
Default Re: JDM gsr to replace usdm? (98 Spec R)
thanks man just what i needed a srtaight up answer
Old Jan 16, 2006 | 05:07 PM
runeminaEF9's Avatar
i second that. the only differences are power related. thats why jdm engines are more coveted than usdm models. good luck with the search.
wing.jai
May 18, 2009 11:34 AM
RuffGsR
Jun 24, 2003 05:29 PM
hotintegranights
Dec 21, 2002 05:20 PM
chirp2hrd
May 28, 2002 12:59 PM
chirp2hrd
May 12, 2002 05:46 PM
