which camber kit? ?wat cams?
Old Jan 15, 2006 | 06:17 AM
Dc2 FrEaK's Avatar
Default which camber kit? ?wat cams?
which camber kit is best for 94 dc2 teg....? which cams can i use if im goin turbo in a couple of months but for best performance now? skunk2 stage I, or stage II?
Old Jan 15, 2006 | 12:12 PM
xtremegsr273's Avatar
the search button is ur friend. lol, there are lots of both. i personally have skunk2 camber kit, but there are plenty of others. as far as the cams, u should probable wait until the turbo is installed. but there are cams specifically for turbo aplications, and lots of them. i'm not sure what they will do for performance without the turbo installed, maybe someone else can help with that. but i would check the engine carefully to make sure it has no problems, then install the turbo, then worry about cams. you'll probably figure it out when u do a search. good luck!
powerfulperformance
Northeast (Sales)
Oct 8, 2007 05:45 PM
blakh
Jun 5, 2007 06:32 PM
londa hover
Nov 15, 2004 12:46 PM
SiR Inspired ED7
Nov 7, 2004 01:27 AM
