!!!!WTB: LS MOTOR !!!!!!!!!!!
just what the post says, i need a ls with or without tranny. ill buy just the head just the block, intake mani, looking to do a swap in a month or too . its going into a 94 del sol so every peice needed for the swap is wanted!
From: gravity rides everything...everything will fall, se GA/ne FL
i have a longblock ('96 block/'92 head). i also have most of the swap parts including obd1 ecu, distributor, stock flywheel and great condition exedy disk, stock pressure plate...maybe the mounts. I'm in jacksonville. i can deliver to you or meet up. pm me if you are still looking.
