TCS and Check Engine Light 2001 V6
Old Jan 14, 2006 | 06:46 PM
fbp cd5's Avatar
Default TCS and Check Engine Light 2001 V6
The TCS and check engine light have been going off occasionally. I have checked the cause for the cel, but could anybody help me determine the cause for the TCS light. Which connector do I jumper (abs?), what pins do I connect, and where is it located on the 2001 V6 model (passenger side under glovebox?). Thanks in advance.
Old Jan 14, 2006 | 06:58 PM
P_Adams's Avatar
Default Re: TCS and Check Engine Light 2001 V6 (fbp cd5)
The TCS (Traction Control System) works in conjunction with the ABS (Anti-lock Brake System) and shares a few sensors with The ECM (Engine Control Module)
and the PCM (Powertrain .....). One of which is the VSS (Vehicle Speed Sensor).
If you have one near, Truddle over to <U>DeathZone Auto Parts </U>and ask if one of their more knowledgeable employees could scan your system for DTC's (Diagnostic Trouble Codes). It should be of the syntax Pxxxx; (greater that P0100).
With that (those) codes, we can continue on to the next step.
Post them here. Most likely several contributors will chime up with pointed suggestions
P
Old Jan 14, 2006 | 06:59 PM
Chiovnidca's Avatar
Get your cel problem straightened out and the tcs light will probably go away too.
Old Jan 14, 2006 | 07:10 PM
fbp cd5's Avatar
Default Re: TCS and Check Engine Light 2001 V6 (Chiovnidca)
I'll check tomorrow morning, but thanks for your help P_Adams. Do you know if you can jumper anything and check the codes for the TCS without plugging in a module to read them?
In regards to the CEL it is a P0401- EGR/Insufficient flow problem. I've been meaning to fix it, but haven't found the time to do so. Too bad it is over the warranty period, but I don't think it relates to the TCS light then again I could be wrong.
Old Jan 14, 2006 | 07:17 PM
P_Adams's Avatar
I believe you need the scan tool for anything other than the ecm (even then it's prefered). (I'll most likely be proven wrong (it happens sometimes ). I've always gone to the diagnostic terminal, so I (truthfully) can't advise you one way or another.
P
Old Jan 14, 2006 | 07:35 PM
YeuEmMaiMai's Avatar
to scan codes for the 6th gen accords you need to jumper pins 8 and 13. turn the ignition on and the codes will flash as in the following example
this would eqaul 12 (EGR)
Pulled this from http://www.v6performance.net
For those of us who won't(can't) spend $$$ in OBD-ii scanners; there is an alternative to find out
about codes and that CHECK ENGINE light that is driving us crazy:
1) Go to Autozone and have them read your codes (it's free)
or
2) See the instructions below
WARNING!!!: USE AT YOUR OWN RISK.
HOW TO OBTAIN TROUBLE CODES MANUALLY (6Th Gen Accord - V6 & I4)
1) Find the Data Link Connector (DLC) located under the instrument panel in the driver's side.
2) Jump terminals 8 and 13 by connecting them with a wire/cable.
...............________
...._____|________|_____
.../|1...2...3...4...5...6...7...8|\
./..|9.10.11.12.13.14.15.16.|..\
DATA LINK CONNECTOR (DLC)
3) Turn the ignition key to ON and observe the "CHECK ENGINE" light. It will flash the trouble codes. For example: 2
long flashes, pause and then 3 short flashes = 23 = P0325 = Knock sensor circuit fault.
One short flash = 1. One long flash = 10. If there is no trouble codes, the light will not flash.
Flashes.....Code(s)............................... ..........Description
1...............P0131,P0132....................... .........Primary heated O2 sensor circuit low/high voltage
3...............P0107,P0108....................... .........Manifold Absolute Pressure (MAP) sensor circuit low/high voltage
4.............. P0335,P0336.................................Cranks haft position sensor
5.............. P1128,P1129.................................Map sensor circuit low/high voltage
6...............P0117,P0118....................... .........Electronic Coolant Temperature (ECT) sensor circuit low/high input
7...............P0122,P0123,P1121,P1122........... Throttle position sensor (TPS) circuit low/high input
8...............P1359,P1361,P1362................. ....CKP/TDC sensor 1
9...............P1381,P1382....................... .........CYP Sensor
10.............P0112,P0113........................ ........Intake Air Temperature (IAT) sensor circuit low/high input
12.............P1491,P1498........................ ........EGR valve
13.............P1106,P1107,P1108.................. ...Barometric pressure sensor
14.............P0505,P1519........................ .........IAC valve
17.............P0500.............................. ..............VSS fault
20.............P1297,P1298........................ .........Electric Load Detector (ELD)
21.............P1253.............................. ..............VTEC
22.............P1257,P1258,P1259.................. ....VTEC
23.............P0325.............................. ..............Knock sensor
41.............P0135,P1166,P1167.................. ....Primary heated O2 sensor
45.............P0171,P0172........................ .........System adaptive fuel too lean/rich
48.............P1162.............................. ..............Primary heated O2 sensor
58.............P1366,P1367........................ .........TDC sensor 2
61.............P0133,P1149,P1163,64,65............ Primary heated O2 sensor
63.............P0137,38,39........................ ...........Secondary heated O2 sensor
65.............P0141.............................. ...............Secondary heated O2 sensor
67.............P0420.............................. ...............Catalyst system efficiency below threshold
70.............P0715,20,25,30,40,53,58,63......... .Automatic transaxle malfunction
71.............P0300,P0301........................ ..........Random/Cylinder 1 misfire
72.............P0302.............................. ...............Cylinder 2 misfire
73.............P0303.............................. ...............Cylinder 3 misfire
74.............P0304.............................. ...............Cylinder 4 misfire
75.............P0305.............................. ...............Cylinder 5 misfire
76.............P0306.............................. ...............Cylinder 6 misfire
80.............P0401.............................. ...............EGR insufficient flow
86.............P0116.............................. ...............Electronic Coolant Temperature (ECT) sensor range/performance
90.............P1456,P1457........................ ..........EVAP control system leak
91.............P0452,P0453........................ ..........EVAP fuel tank pressure sensor low/high input
The codes that will not flash are as follows (will need code scanner):
P1607-PCM internal circuit failure and
P1705,06,38,39,53,68,73,91-Automatic transaxle failure
HOW TO CLEAR TROUBLE CODES (after fixing problem)
1) Remove ignition key (OFF)
2) Locate fuse panel on passenger's side (open door)
2) Remove fuse no. 13 (7.5 amp) for 10 seconds, and then place it back in.
I hope this info helps you, as much as it helped me.
Enjoy!
Modified by YeuEmMaiMai at 7:05 AM 1/15/2006
Old Jan 14, 2006 | 07:59 PM
NAiL05's Avatar
They had a TSB on sixth gen EGR's if i remember correctly. If you havent changed it I would take it back to the Honda dealership and see if it applies to your vehicle.
Old Jan 14, 2006 | 11:06 PM
Chiovnidca's Avatar
Default Re: (NAiL05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">They had a TSB on sixth gen EGR's if i remember correctly. </TD></TR></TABLE>
Yep, 8 year 80,000 mile warranty extension.
Old Jan 15, 2006 | 04:07 AM
Default Re: (Chiovnidca)
my car has close to 90K on it and the dealer fixed it for me no charge. If you have a 5th gen and are in CA, you are covered for 150K on some emmisions stuff.
Old Jan 15, 2006 | 09:33 PM
fbp cd5's Avatar
Default Re: (YeuEmMaiMai)
I just stopped by Autozone today and used their OBDII scanner. The only code stored was P0401, which I already know corresponds to the EGR insufficient flow problem. I still don't know why the TCS light would come on. Any ideas on how to check the cause for the TCS light?
Old Jan 16, 2006 | 02:41 AM
Chiovnidca's Avatar
Default Re: (fbp cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fbp cd5 &raquo;</TD></TR><TR><TD CLASS="quote">I just stopped by Autozone today and used their OBDII scanner. The only code stored was P0401, which I already know corresponds to the EGR insufficient flow problem. I still don't know why the TCS light would come on. Any ideas on how to check the cause for the TCS light?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Get your cel problem straightened out and the tcs light will probably go away too.</TD></TR></TABLE>
Old Jan 16, 2006 | 07:16 AM
NAiL05's Avatar
It might be the same as my friend lex when we diagnosed it. Usually when the engine senses a fault that causes driveablility problems the TCS and the Check engine will light up together. When you get the EGR code fixed both the TCS and Check Engine light should go away.
Old Jan 16, 2006 | 10:08 AM
fbp cd5's Avatar
Thanks guys. I'll take care of the EGR code today and see what happens.
Old Jul 14, 2024 | 11:27 AM
Robert Thompson's Avatar
MY CHECK ENGINE LIGHT COMES ON,AFTER CLEARING THE DTC,IT WILL SOMETIMES POP BACK ON,(P0171)AND NOW WHEN EVER IT DOES MY TCS COMES ON SIMULTANEOUSLY.IVE BEEN TRYING TO FIGURE THE P0171 OUT HAVEN'T NAILED IT YET,AS IM SURE YOU KNOW IT CAN BE A PLETHORA OF THINGS,BUT I FIGURED IF THE TCS COMES ON IT MIGHT HAVE NARROWED IT DOWN. THANX
P
1slowcrx
Dec 6, 2011 04:51 AM
1slowcrx
Dec 5, 2011 01:30 PM
SrVShayner
Aug 17, 2009 11:40 AM
rluder21
Apr 10, 2006 06:00 PM
mandyb
Feb 25, 2006 02:56 PM
