engine VIN number ? is it the same
Old Jan 14, 2006 | 05:41 PM
JUN.'s Avatar
Default engine VIN number ? is it the same
hi I have a d16y7 engine...
does the # that appears below where it says D16y7, that number is it supposed to be the same VIN # as the car ? Or am I looking at the wrong VIN # of the engine
also, in the transmission, there is a sticker with some numbers....... Are they all need to be the same ??
thanks for the help
Old Jan 14, 2006 | 05:46 PM
payneth's Avatar
Default Re: engine VIN number ? is it the same (pakipr)
Well they all should be the same. Unless you switched out motors.
Old Jan 14, 2006 | 05:50 PM
JUN.'s Avatar
Default Re: engine VIN number ? is it the same (payneth)
but the engine number is about 8 long ?
and the VIN its like 15 lol, I think im looking at the wrong engine number
Old Jan 14, 2006 | 06:06 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pakipr &raquo;</TD></TR><TR><TD CLASS="quote">does the # that appears below where it says D16y7, that number is it supposed to be the same VIN # as the car ? Or am I looking at the wrong VIN # of the engine
no.
d16y7 is the block code
the number under that is the serial # of the motor
Old Jan 14, 2006 | 06:10 PM
JUN.'s Avatar
Default Re: engine VIN number ? is it the same (eda6)
so If the VIN of my car is : JHMED9366KS001030, then in the engine belod D16y7 ( if the motor hasnt changed,,,example) its supposed to have: JHMED9366KS001030
Old Jan 14, 2006 | 06:15 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pakipr &raquo;</TD></TR><TR><TD CLASS="quote">so If the VIN of my car is : JHMED9366KS001030, then in the engine belod D16y7 ( if the motor hasnt changed,,,example) its supposed to have: JHMED9366ks001030</TD></TR></TABLE>
no. The serial and vin #'s are not related.
Old Jan 14, 2006 | 06:18 PM
JUN.'s Avatar
and how do I know the engine is from the car ?
in this case, I know the engine is not from the car, but im trying to help a friend
Old Jan 14, 2006 | 09:23 PM
jacoop86's Avatar
i thought that engine serial numbers and vin's were related, but you would have to talk to honda or go through some other channels to find out if the engine had been swapped. i think that cops can find engines that have been chopped out stolen cars buy matching vin and serial numbers.
Old Jan 15, 2006 | 07:21 AM
JUN.'s Avatar
Default Re: engine VIN number ? is it the same (jacoop86)
so, I found some info on this
the VIN number of the car has to be related with the VIN of the engine.... which is located is on the block on front of the radiator and on top of the oil pan
Linked
Apr 13, 2011 05:24 PM
3s0n3
Feb 17, 2006 02:36 PM
Civic168
Nov 28, 2005 10:21 AM
94CivicSi
Apr 7, 2005 06:03 AM
