How many bulbs in 90-93 Integra cluster?
Old Jan 14, 2006 | 02:51 PM
BoostinEJ1's Avatar
Default How many bulbs in 90-93 Integra cluster?
Just wanted to know how many bulbs are back there, wanna buy some new ones and haven't had a chance yet to rip the cluster out... Thanks.
Old Jan 14, 2006 | 03:39 PM
BoostinEJ1's Avatar
well i searched and all i could find is for an EG so i'll just buy 6 bulbs and hope there the same.
Old Jan 14, 2006 | 03:59 PM
b62pteg#2's Avatar
Default Re: (simple DB2)
You need to get over to G2IC I've written up about this topic many a time for poeple when they convert to LEDs for their clusters, etc. Anywhere here's a quick rundown, as taken from one of my posts from one of the threads about it:
"2 194 "wedge" bulbs for the cluster (a third one will be needed if you plan on replacing the low gas light indicator, but only 2 are actually needed for lighting the cluster up)
3 74 bulbs for the cluster itself
2 74 bulbs for the light bar above the cluster (i didnt put them in for my conversion, though. I found it took away too much from the look I was going for)
2 74 bulbs for lighting behind the selector for where you want the air to blow
1 74 bulb for temp control
1 74 bulb for the ashtray
1 74 bulb for the cig light illumination
The light above the CD player/headunit, I had to buy an LED, solder (in series) the correct resistance (used two resistors, different ohms), then soldered that inline with the supplied positive/negative wires that were already there).
That should be all the correct lighting, listed above. This does not include any of the lighting for the hazard/defog/etc switches. Any questions, let me know."
If you need to know more, ask me, or search over there for "LEDs, gauge, cluster" things of that nature/combo of those terms. You'll pull up a lot.
-- Kevin
Old Jan 14, 2006 | 04:06 PM
BoostinEJ1's Avatar
thanks man
Old Jan 14, 2006 | 04:07 PM
b62pteg#2's Avatar
No prob man, good luck with it
-- Kevin
chiliphil1
Feb 3, 2012 04:36 PM
ef93si
Jan 29, 2006 06:29 PM
BuBBa y0!
Jun 13, 2005 02:46 AM
d15b7racer
Sep 5, 2003 08:37 AM
