Oil leak..need some help finding it
Old Mar 20, 2002 | 10:38 PM
IntegD's Avatar
New User
Default Oil leak..need some help finding it
I need some help diagnosing where my oil leak is coming from. Its all over the drivers side of the hood and the drivers side of the engine bay. It looks like the timing belt is slinging it backwards towards the power steering rack and wheel. I tried to check the oil pump and oil filter and the oil sensor on the block, they all look pretty clean. I also replaced the oil pan gasket, still leaks.
P.S. Its not leaking from the headgasket....TIA
Old Mar 20, 2002 | 10:44 PM
t's Avatar
t
Default Re: Oil leak..need some help finding it (IntegD)
Did you recently install some cams or cam gears? Check the cam seals that are located behind the cam gears.
Old Mar 21, 2002 | 05:29 AM
TodaCivic's Avatar
Default Re: Oil leak..need some help finding it (t)
D, the cams seals came loose on me first time i did my toda's, so i'd check those.
It sprayed oil in same places.
Well good luck on that man.
LATER
M@
Apr 25, 2006 08:30 AM
DAintegraGSR
Apr 28, 2005 08:22 PM
B2FiNiTY
May 22, 2003 09:47 AM
2000vsm
Oct 22, 2002 03:21 PM
