NEED HELP ASAP NO SPARK
Ok i got a 92 honda accord. The car won't start. I'm getting no spark. This is what i've done:
Changed out timing belt and water pump. Did it 3 times and everything lines up.
Changed out spark plugs, wires, rotor button, and cap. Changed out the dizzy and rebuilt 2 dizzy with new parts. I also tried both dizzies that i rebuilt on another car it sparks and works fine. All the fuses have been check. Changed out the ecu also even 4 different main relay. I got voltage going to the dizzy and wires, just making sure the harness isn't shorted out. Ground wires are all on. If anyone got some ideas let me know. The ecu came from a running car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmVtecy0 »</TD></TR><TR><TD CLASS="quote">yes i have tried 3 diffrent dizzys</TD></TR></TABLE>
the coil on a 92 is external, it is not in the dizzy,,
micah13x
11
Apr 14, 2011 03:09 PM
vtec92accord
Mar 13, 2007 06:26 PM
