Need Help Of Tranny Mount For 5Gen Swap
Old Jan 14, 2006 | 12:37 AM
remaxxxk's Avatar
Default Need Help Of Tranny Mount For 5Gen Swap
After searching, searching and reading and now start collecting part for the swap, come across one tranny from 95-96(m2f4), my question is the tranny mount fittment,
95-96 MT Tranny
97 AT Tranny
97 AT Tranny
form the writeup I had read, people do replace the mount no question at all, but they didn't clearify is to replace the bracket or the rubber mount?
1) according to the part list above, rubber mount for AT & MT looks a like, it is just replace the bracket and use existing rubber mount?
2) will the 97 tranny mount bracket direct bolt onto 95-96 tranny, the shape and bolt hole seems like big different according to the part list
To those who had complete the swap, please advise me, is there any other thing I had to watch out, I will keep my auto ecu and rechipped it according to the writeup (auto => mannual convert), after that I just can toss the TCM right???? and wiring only need to be done on reverse, speed & cruise right??????
also come across the drive shalf issue, had check the part list too, both 97 driver side had the same part number so that's mean I can reuse it right, but the ebayer link below said need two???????
http://cgi.ebay.com/ws/eBayISA...&rd=1
appreciate of all the input, can't wait to get it start.
Modified by remaxxxk at 1:55 AM 1/14/2006
Old Jan 14, 2006 | 08:19 AM
remaxxxk's Avatar
Default Re: Need Help Of Tranny Mount For 5Gen Swap (remaxxxk)
bump to top
Old Jan 14, 2006 | 08:56 AM
remaxxxk's Avatar
anyone out there????????????????
Old Jan 14, 2006 | 09:06 AM
need_a_h22's Avatar
Not to threadjack but do you have a link to those pics?
Old Jan 14, 2006 | 04:46 PM
remaxxxk's Avatar
Default Re: Need Help Of Tranny Mount For 5Gen Swap (need_a_h22)
is from online honda dealer, just copy and paste, don't rememeber what is the excact addresss but u can search for aprt list.
got it: hondaautomotiveparts.com
Modified by remaxxxk at 7:54 PM 1/14/2006
Old Jan 15, 2006 | 08:40 AM
need_a_h22's Avatar
thanks!
Old Jan 15, 2006 | 05:15 PM
remaxxxk's Avatar
no one??????????????????????????????????????????????? ?????????
Old Jan 15, 2006 | 06:45 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remaxxxk &raquo;</TD></TR><TR><TD CLASS="quote">form the writeup I had read, people do replace the mount no question at all, but they didn't clearify is to replace the bracket or the rubber mount?
Yes, you can use your existing rubber mount. Just replace the bracket.
Yes, it will bolt right up without a problem
To those who had complete the swap, please advise me, is there any other thing I had to watch out, I will keep my auto ecu and rechipped it according to the writeup (auto =&gt; mannual convert), after that I just can toss the TCM right???? and wiring only need to be done on reverse, speed & cruise right??????
After you rechip your ECU, you may disgard the TCM. You will only need to wire the reverse, the clutch safety switch, and the cruise control.
You can reuse your stock AT axles, but not the driveshaft. The item in that link is an axle and not a driveshaft, so you won't need that one. You will need to get the driveshaft from a MT though.
You're welcome and goodluck. If you have further questions, just let me know.
Modified by remaxxxk at 1:55 AM 1/14/2006</TD></TR></TABLE>
Old Jan 15, 2006 | 07:36 PM
remaxxxk's Avatar
Default Re: Need Help Of Tranny Mount For 5Gen Swap (khalal538)
About the drive shalf - half, it is pic below?
it is other part reuseable? and just replace the shalf all the way to left in the pictue?
thank alot, kevin, now I am totaly clear. very nice car u have, like the Mugen Kit very much.
Modified by remaxxxk at 8:46 PM 1/15/2006
Modified by remaxxxk at 8:50 PM 1/15/2006
Old Jan 16, 2006 | 06:54 PM
K-Spec's Avatar
Yes, the half shaft is the one to the far left with a box around it. That is all you need, you can reuse your stock axles. Thanks for the comments
BigDaddyRich
Oct 27, 2011 11:31 AM
mr_ek9
Jan 30, 2006 02:33 PM
Rob_Dog
Nov 13, 2004 10:44 PM
fengxzhang
Jan 14, 2004 01:29 PM
Egone
Oct 26, 2003 01:48 AM
