Lugnut Pricing..
I plan on getting some enkei 17" rims and tires from a dude i know and he has the 4 rims and tires - but no lugnuts.
How would i go about aquiring lugnuts for these rims and how much would they cost?
here is a link to his ad he posted
http://azpunk.backpage.com/buy...parts
well... when i needed lugnuts when i killed my hub, studs, bearing, and rim... i got 4 new ones from my honda dealer for 4 bucks... but i dont know if factory lugnuts would work, but thats what i did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Flaps »</TD></TR><TR><TD CLASS="quote">Well my factory lugnuts are black - and the rims are gunmetal - im not sure how good that would look? </TD></TR></TABLE>
gunmetal and black match perfectly fine.
I want to get some Skunk2 Racing forged lugnuts for my new wheels($5.00 each).
Anyone want to point me in a good direction for black/black chrome anti-theft lug-nuts....Edge racing supplied lug nuts with my wheel purchase, they but they werent anti-theft tuner style....
Chris
Chris
I got each of my wheels done for 10 bucks a wheel plus the balancing and alignment which i get for free at Tire Kingdom. I had to purchase a new lugset to match the lugnut head configuration on the Rota Subzero's. The chrome Gorilla lugs were 50 bucks for the set of 20.
Modified by msedacca at 6:40 AM 1/15/2006
go to your local parts store and pick lug a set of nuts up for what they will probably call tuner wheels. I have seen them in various colors last time I was up there to buy mine (in stock and on the shelf).
m12-1.5's is the size and thread pitch you need I believe.
I was looking on ebay and im seeing auctions like this...
Mustang Lugnuts - Set of 20 - 12x1.5mm Tuner Lugnuts
Will those work even though it says mustand - arent lugnuts universal?
EDIT - http://cgi.ebay.com/ebaymotors...QrdZ1
will those work? 30 isnt a bad price.
What you need to do is take one of the rims into the tire place and have them tell you what the lug style is. There are 3 different ones
1 - \
2 - ) (like a half circle)
and I forget the third one. someone else should know
Basically all you need is the lug style and thread style since you already know the bolt pattern which is 5x?. And your thread style is 12x1.5 (i assume)
If not you can try checking the Enkei website if all else fails.
1 - \
you have a 4x114.3, the approprate lug nut is 12x1.5 with a conical seat , one that looks like this: \ /, and you probably want "tuner style" becuase they have a small overall diameter to fit into the holes on your rim, most rims that arent double drilled (like my 5Zigen FNO1RC's) dont require a tuner lug nut.
Anyway, I am still looking for a good source to purchase these lugnuts from....I dont want to spend an arm and a leg, but I want good security lug nuts in a black/black chrome color...hmmm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krispyaccord »</TD></TR><TR><TD CLASS="quote">you have a 4x114.3, the approprate lug nut is 12x1.5 with a conical seat , one that looks like this: \ /, and you probably want "tuner style" becuase they have a small overall diameter to fit into the holes on your rim, most rims that arent double drilled (like my 5Zigen FNO1RC's) dont require a tuner lug nut.
you nail'd it.
factory have a round seat, don't put them on aftermarket wheel because they will not seat correctly.
and factory lugnut are wider and you cannot stick them in. you'll need a set of tuner nut and have the "stick in" key.
you nail'd it.
