motor mounts
Old Jan 13, 2006 | 05:26 PM
george34's Avatar
Default motor mounts
I need atleast one new motor mount for my d16a6. my passanger motor mount is cracking bad and I figure that it would be a good time to change all the mounts. Is there any company that makes stiff motor mounts for a good price. I saw that hasport makes mounts but they are like $450. My other opition that I'm thinking of is prothane inserts. But it sounds like you have to press them in and I don't have a press. Any options on fixxing or replacing the motor mounts will help.
Old Jan 14, 2006 | 04:48 AM
george34's Avatar
Default Re: motor mounts (george34)
up for some help.
Old Jan 14, 2006 | 04:54 AM
dr_latino999's Avatar
You can't get aftermarket D-Series mounts, if you have a cracked mount here is a good plan of action -
Purchase a new used one in good condition (I have a couple laying around)
Purchase some inserts
Inserts need to be pressed in alright.....with your hand
Put back in and enjoy
Sound good to you?
Old Jan 14, 2006 | 05:28 AM
george34's Avatar
Default Re: motor mounts (dr_latino999)
can you post pics of the mounts you have? Won't the inserts work if the rubber of the mount is cracked? How much would oyu want for the mounts? With the inserts would I have to take all the old rubber out of the mount to get the insert in? What is a good price on prothane inserts?
Old Jan 14, 2006 | 05:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by george34 &raquo;</TD></TR><TR><TD CLASS="quote"> can you post pics of the mounts you have? Won't the inserts work if the rubber of the mount is cracked? How much would oyu want for the mounts? With the inserts would I have to take all the old rubber out of the mount to get the insert in? What is a good price on prothane inserts? </TD></TR></TABLE>
Pictures - Later when I tackle cleaning the garage
Inserts will work with cracked rubber, but I like starting from new rather then patching it back up.
No, you just slip in the inserts which is pre-molded to the depressions in the mounts
Depends on if it is for the front/rear or side/passenger. Shouldn't be more then 50$ for all four corners covered.
Old Jan 14, 2006 | 05:55 AM
george34's Avatar
Get some pics up I may be interested. If you have ever had a car or been in a car with inserts, does it make the car really noise(lots of rattles and squeaks? is it worse than like hasport mounts?
Old Jan 14, 2006 | 07:13 AM
HondaFerris's Avatar
a lot of people make there own mounts too...go to home depot and get some PL Polyerythane or go to your local auto parts store and buy some window weld...thats the poor mans way to do it...
Here ya go: http://importnut.net/motormount.htm
Old Jan 14, 2006 | 03:58 PM
george34's Avatar
Default Re: motor mounts (HondaFerris)
is the PL polyerythane a caulk(sp) like the window weld is? I think I'm going to try one of these before I buy inserts or mounts. If the PL polyerthane is a caulk then I will probably use that over the wendow weld because it will probably be stiffer.
Old Jan 14, 2006 | 04:14 PM
Sho Pow's Avatar
I just got prothane inserts for the trans mounts and It makes a world of difference. Its stiff as hell as I still need the driver side mount.
Old Jan 14, 2006 | 05:34 PM
george34's Avatar
Default Re: (Sho Pow)
do the prothane inserts make any noise? like squeaking? I now they will make more vibration in the car. How much did you pay for your inserts? where did you get them? and did you use old cracked mounts or did you get mounts that were in good shape? Thanks
Old Jan 14, 2006 | 05:40 PM
abnaasefmb's Avatar
Default Re: (george34)
just hit it with the window weld. PL is the brand name, i just did a set today and was too easy.
BiG Chris's Avatar
yea ide like to know where to get the inserts as well
Old Jan 15, 2006 | 04:46 AM
george34's Avatar
Default Re: (BiG Chris)
I found inserts on lightningmotorsports.com for $43 for all four. I don't know if that os a good price?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">just hit it with the window weld. PL is the brand name, i just did a set today and was too easy.</TD></TR></TABLE> So the stuff is call PL window weld? Does M3 also make window weld b/c in that link that was posted the guy said to use M3 window weld? What is the full name of the product you used? thanks
Old Jan 15, 2006 | 05:16 AM
i used a mount kit for my front mounts and for my rear mount i used "PL Polyurethane Premium Construction Adhesive" comes in a yellow caulking tube with a red stripe.
Old Jan 15, 2006 | 05:26 AM
BlueCrxNC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by george34 &raquo;</TD></TR><TR><TD CLASS="quote">I found inserts on lightningmotorsports.com for $43 for all four. I don't know if that os a good price?
I got my Prothane inserts (FULL SET = All four mounts) there just a year and a half ago for $34 shipped! Prices are always going up
Old Jan 15, 2006 | 06:29 AM
george34's Avatar
Default Re: (BlueCrxNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">
I got my Prothane inserts (FULL SET = All four mounts) there just a year and a half ago for $34 shipped! Prices are always going up </TD></TR></TABLE>
How do you like them?
So what does everyone think I should do fill the the mounts with polyurethane or use the prothane inserts??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFerris &raquo;</TD></TR><TR><TD CLASS="quote">i used a mount kit for my front mounts and for my rear mount i used "PL Polyurethane Premium Construction Adhesive" comes in a yellow caulking tube with a red stripe. </TD></TR></TABLE>
Why did you only use polyurethane for only the rear mounts?
Old Jan 15, 2006 | 08:51 AM
i bought the kit used and it only came with 2 front mounts...so i made my own rear mount...
Old Jan 15, 2006 | 10:52 AM
abnaasefmb's Avatar
So the stuff is call PL window weld? Does M3 also make window weld b/c in that link that was posted the guy said to use M3 window weld? What is the full name of the product you used? thanks</TD></TR></TABLE>
$6 for a can of PL
Old Jan 15, 2006 | 05:11 PM
BlueCrxNC's Avatar
The Prothane Inserts come with all 4. Energy Suspension... I'll find pics. I actually called a dealer and had them take pics comparing the two manufacturer's products.
I love them. At first the vibrations are wild... they simmer down after a while though. Originally I couldn't figure out why I kept ruining axles turned out to be the front tranny mount was broken and the inserts stopped the trend.
The Window Weld or other such products do work, but if you're mounts are torn to pieces it'll be harder to center the pin in the correct place while the material hardens... if you mess up, you gotta get new used mounts or somehow get the material back out.
Old Jan 15, 2006 | 05:30 PM
crx2nr822's Avatar
Go to the junkyard and find a stock mount to replace your cracked one and throw some polyurethane inserts in and call it a day
Old Jan 15, 2006 | 07:17 PM
george34's Avatar
Default Re: (crx2nr822)
my mounts are not totaly gone they just have a few crack in them so I thought I would so what I could do about mounts. Also I figured having stiff torque mounts would be nice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2nr822 &raquo;</TD></TR><TR><TD CLASS="quote">Go to the junkyard and find a stock mount to replace your cracked one and throw some polyurethane inserts in and call it a day </TD></TR></TABLE>
There is no local junkyard that will have mounts.
I'm probably get the polyurethane and fill the mounts or buy inserts for the mounts that are no my car now.
Old Jan 22, 2006 | 07:30 PM
BlueCrxNC's Avatar
Pics comparing the Energy Suspension Inserts and the Prothane Inserts. All the inserts are the same with one exception being the front transmission mount. Energy Suspension uses a 2 piece unit while Prothane uses a single piece unit.
Kaspk
17
Jan 19, 2008 06:54 PM
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
Ls On StErIoDs
Oct 21, 2005 09:39 AM
rocketfuelcerx
Apr 8, 2005 11:53 AM
ragejed
May 18, 2002 06:56 PM
