Brakes or wheel bearing?
Old Jan 13, 2006 | 04:51 PM
Luchini's Avatar
Default Brakes or wheel bearing?
Symptoms: Whenever the car is in motion a high hissing/ metal to metal contact sound is coming from the right rear wheel well. When car is moving in reverse the sound changes to a dying mooing cow. Sometimes after driving a burning smell similiar to burning metal is present.
Suggestions? Should I stop driving it till its fixed or is the problem minor?
Old Jan 13, 2006 | 06:06 PM
in9teg2ra's Avatar
Default Re: Brakes or wheel bearing? (Luchini)
i guess a locked up e-brake cable or caliper could be the cause.
Old Jan 13, 2006 | 07:05 PM
P h i l's Avatar
Default Re: Brakes or wheel bearing? (in9teg2ra)
if it is its drums just take the housing over the shoes off because all the gases and debree in it and dust can make it squeak and stuff but it sounds like you should replace the shoes and hard wear.
but its defentiley not a wheel bearing if you want to test just jack your car up let it idle and by the back of the wheel bearing take a screw driver put it by the back of the wheel bearing and put your ear on the plastic if you hear a huming sound its bad if not your good to go.
Old Jan 13, 2006 | 07:07 PM
TheNosR's Avatar
Default Re: Brakes or wheel bearing? (crxhf89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhf89 &raquo;</TD></TR><TR><TD CLASS="quote">if it is its drums just take the housing over the shoes off because all the gases and debree in it and dust can make it squeak and stuff but it sounds like you should replace the shoes and hard wear.
but its defentiley not a wheel bearing if you want to test just jack your car up let it idle and by the back of the wheel bearing take a screw driver put it by the back of the wheel bearing and put your ear on the plastic if you hear a huming sound its bad if not your good to go. </TD></TR></TABLE>
i wrote this on my friends name on accident
Old Jan 13, 2006 | 10:07 PM
Dartanian's Avatar
Sounds like a seized caliper. Check the rotors for any extreme heat differences after driving.
I know what worn wheel bearings sound and feel like, and that just doesn't sound like they are bad.
Old Jan 14, 2006 | 06:41 AM
Luchini's Avatar
Default Re: Brakes or wheel bearing? (Das Schmoo)
thanks guys. i thought it was the wheel bearing but i dont think that would cause the burning metal smell. im prob just gonna take it to a brake shop cuz it sounds like it could be a variable of things and i dont wanna expletive around with brakes since im driving from WA to FL in a couple weeks.
Old Jan 16, 2006 | 10:35 AM
Luchini's Avatar
Weird. After driving it about 5 seperate times the sound just went away. Maybe something was just stuck and it dislodged itself after a while.
dj-t
11
Feb 8, 2008 06:03 AM
Minglor
May 29, 2006 10:00 PM
frostcivic
May 11, 2006 02:23 AM
vtecdc2
Sep 28, 2003 04:34 AM
DSPDA3
Jan 4, 2003 12:21 PM
