Speedometer with jumping needle problem
Old Jan 13, 2006 | 04:41 PM
johnjjy's Avatar
Default Speedometer with jumping needle problem
My speedometer have been acting up lately. The needle have been bouncing up and down and recently it like to stay at 0 mph even when I am driving at freeway speeds.
Any technical advise?
Old Jan 13, 2006 | 05:01 PM
Jammersplace's Avatar
Default Re: Speedometer with jumping needle problem (johnjjy)
try reconnecting the sensor plug on the tranny thats what fixed mine.
Old Jan 13, 2006 | 05:25 PM
Out of every
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jammersplace &raquo;</TD></TR><TR><TD CLASS="quote">try reconnecting the sensor plug on the tranny thats what fixed mine.</TD></TR></TABLE>
try that if that doesnt work. had the same problem had to get another speed sensor
Old Jan 14, 2006 | 02:02 AM
transpar_nt's Avatar
To more fully answer your question, the answer is most likely your vehicle speed sensor (vss). Basically its a piece that has a shaft with a little gear on the end that sticks into the transmission. You'll need to pull it out and pick all of the junk caked around it off, and then clean it really well with some simple green or some parts cleaner and pop it back in.
The vss is located at the top of the tranny near the back, sticks straight up, has an electrical plug on it, and is directly behind the starter. To get it out you need to remove the tall 10mm bolt and then pull up and twist clockwise on the vss. DO NOT REMOVE ANY OTHER BOLTS!!
CHK4TIX
Apr 18, 2008 08:40 PM
RioSmAn
15
Sep 5, 2007 07:16 PM
one slow coupe
Nov 30, 2006 12:30 PM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
