water leak?
Old Jan 13, 2006 | 04:29 PM
95LStizzy's Avatar
Default water leak?
i recently noticed water leaking around left tail light when it rains? does anybody have a remedy to fix this or any sugestions on how to?
Old Jan 13, 2006 | 05:17 PM
CRX Toad's Avatar
Default Re: water leak? (Red89EfHatch)
Also do a little search....it is in the upper right. This has been covered eleventy billion times.
Old Jan 13, 2006 | 11:57 PM
jisu009's Avatar
Default Re: water leak? (CRX Toad)
I just replaced my taillight gaskets and it still leaks like a siv.
Old Jan 14, 2006 | 12:55 AM
crxnj's Avatar
Default Re: water leak? (jisu009)
I used some of that clear **** stuff from home depot on the tail lights..Seems to work for now..But I still have leaks from the wind shield,sun-roof,and hatch.. ..I'm gonna use the **** on the windshield also and see what happens..Every one I know that has one of these cars has leaks..
Old Jan 14, 2006 | 01:52 AM
delphi-dada's Avatar
Default Re: water leak? (Mr.speaker)
haha...awesome, clear "****"
caulk right?
i had a leak in the rear of my hatch too, but in my case its the drain tube from the roof that was all clogged up
Old Jan 14, 2006 | 06:49 AM
eda6's Avatar
probably needs new gaskets..either buy new or make your own
making your own requires (cheaper than 1 gasket from honda):
1'x2' piece of 1/8" neoprene gasket material
1/2" copper couplings (used as a hole punch)
4 lb hammer (makes your hole punch work better)
utility knife
sharpie
ratchet and extension with 8mm socket
easy job with the above tools. Mine have lasted for a year so far.
Old Jan 14, 2006 | 08:41 AM
GreenMachineRex's Avatar
Default Re: (eda6)
Buy new gaskets!
JDMThoughts
May 17, 2008 01:58 PM
Kyles ej1
12
May 10, 2005 03:40 PM
jamal-188
Apr 9, 2005 07:47 AM
deceit
May 21, 2002 06:40 AM
fiebru1119
Feb 26, 2002 03:58 PM
