TIRE NOISE
Old Jan 13, 2006 | 04:20 PM
BlUeHoOdCiViC99's Avatar
Default TIRE NOISE
Azenis concern i have 205 50 15 all around on my SI rims on my 99 coupe my question is when i put the tires on when they where new the ride noise was Ok but as the tires been getting older iam starting to hear a thumping noise i thought it was my bearings changed them and still the same noise really thinking it could be the tires What do you H-T people think thanks any info/feedback would be cool
Old Jan 13, 2006 | 10:01 PM
_BEN_'s Avatar
Default Re: TIRE NOISE (BlUeHoOdCiViC99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUeHoOdCiViC99 &raquo;</TD></TR><TR><TD CLASS="quote">but as the tires been getting older iam starting to hear a thumping noise </TD></TR></TABLE>
Inspect your tires throughly for bubbles or bulges. If you find a bubble or bulge you should drive as slow as you can to your local tire store and have them replaced asap. Or even safer remove the rims and take a different car.
Old Jan 16, 2006 | 02:17 PM
Default Re: TIRE NOISE (_BEN_)
bump
Old Jan 16, 2006 | 02:53 PM
old man neri's Avatar
Have you checked your pressure lately? What is it?
Old Jan 16, 2006 | 06:49 PM
Default Re: TIRE NOISE (old man neri)
check the tires pressure and everything i even rebalanced and rotated the tires same noise
Old Jan 17, 2006 | 04:41 AM
boostinaintez's Avatar
check your suspension for loose parts raise your front end and wiggle your tires from side to side and up and down for any play, sounds to me like a ball joint or tie rod end rarely will a tire make a thumping noise just my 2 cents
Old Jan 17, 2006 | 11:04 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUeHoOdCiViC99 &raquo;</TD></TR><TR><TD CLASS="quote">Azenis concern i have 205 50 15 all around on my SI rims on my 99 coupe my question is when i put the tires on when they where new the ride noise was Ok but as the tires been getting older iam starting to hear a thumping noise i thought it was my bearings changed them and still the same noise really thinking it could be the tires What do you H-T people think thanks any info/feedback would be cool</TD></TR></TABLE>
sounds like your tires are choppy...caused by uneven wear from bad toe adjustment....more than likey the inner edge...
have you done an alignment within 15K miles? if not..get one...
Old Jan 21, 2006 | 09:07 AM
Default Re: TIRE NOISE (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">
have you done an alignment within 15K miles? if not..get one...</TD></TR></TABLE>
Its not my front suspension because i changed my axles and checked everything joints etc everything looks to be very tight BUT i was thinking that with the tires uneven wear and tear so what iam going to do is change my tires no not buy new once since i just put all season falcan tires on my sisters civic and see if that will eliminate the noise keep you posted thanks for your help guys
Regards Junior
Old Jan 21, 2006 | 04:18 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUeHoOdCiViC99 &raquo;</TD></TR><TR><TD CLASS="quote">Its not my front suspension because i changed my axles and checked everything joints etc everything looks to be very tight BUT i was thinking that with the tires uneven wear and tear so what iam going to do is change my tires no not buy new once since i just put all season falcan tires on my sisters civic and see if that will eliminate the noise keep you posted thanks for your help guys </TD></TR></TABLE>
I still think it would be useful to check your alignment your alignment might be causing that uneven wear and tear the uneven wear and tear is what causes the noise the problem could be easily corrected by paying an hour of labor to get your car aligned if you don't get your car aligned you won't necessarily know what caused the noise or what caused the tires to wear unevenly btw most people use punctuation between their sentences so they don't all run together like this do you really talk like this in person it makes it really hard to understand your posts i'm sure you want people to understand you so they can answer your questions punctuation will help you any time you want to make yourself understood it's a good idea to throw in a period at the end of each sentence and to start each sentence with a capital letter people will understand you better good luck with the alignment and with figuring it out take care
Old Jan 21, 2006 | 05:08 PM
Default Re: TIRE NOISE (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
I still think it would be useful to check your alignment your alignment might be causing that uneven wear and tear the uneven wear and tear is what causes the................................... </TD></TR></TABLE>
When I first read this I was surprised that you would make such blatant poor use of grammar. Then I realized that you were just being sarcastic *****. I love it...lol
Cheers.
Old Jan 25, 2006 | 08:37 PM
Thanks for everything, but i was at work trying to type fast so the last thing I thought about was periods ect. Just wanted to get my point, concern accross.
r1lsr
Aug 10, 2008 08:04 PM
atcBrodie
Honda Civic (2006 - 2015)
Jun 13, 2008 03:59 AM
codyb13
Apr 14, 2005 05:41 PM
ebayjackal1598
Jan 20, 2004 10:12 AM
deviant1
Apr 12, 2003 12:23 PM
