how do you get these out?
ive been trying to get these bolts for the bumper out but they just wont come out and now there like half way striped. any suggestions, can i just drill them out? or use a bolt extractor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_18 »</TD></TR><TR><TD CLASS="quote">Maybe some Anti-seize and the correct type screwdriver will help?</TD></TR></TABLE>
While the correct screwdriver will help, applying antisieze to it WILL NOT.
they don't pop out they have to be unscrewed. Try some PB Blaster and an impact driver. I used vice grips on mine because I broke the impact driver bit on mine trying to get them out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">use a fatter tip phillips head. that worked for me</TD></TR></TABLE>
If you are tring to get the bumper off their is no point in taking those out, just get the bolts that hold the bumper support on and the whole thing will come right off.... Its only 4 bolts instead of all those PITA ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98exdream »</TD></TR><TR><TD CLASS="quote">they all are plastic u can pop them or pull them out with a niddle nose that works as will</TD></TR></TABLE>
On the Ek's, but not on his EG, those were a pain on my buddies teg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTeg »</TD></TR><TR><TD CLASS="quote">If you are tring to get the bumper off their is no point in taking those out, just get the bolts that hold the bumper support on and the whole thing will come right off.... Its only 4 bolts instead of all those PITA ones</TD></TR></TABLE>
Those 5 bolts will still need to come off in order to get the bumper off. There is no other way around it. They aren't hard to get off if you use the right tool.
for all of you that think you can pop them out like an EK, no. they are screw in fasteners.
if you think you can take the bumper off by taking off the support, no. the support does not secure the bumper on an EG in any way.
use a pair of vise grips and grab the side of the fastener. you can also heat the fastener slightly and tap on it with a ball peen hammer to loosen it from the threads. short of that, you will need to grind/ drill the fastener out.
Vice grips worked for me! The screws were too rusted and shitty for me to reuse them anyway. I put the 3 that were still good back in and chucked the other 2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northkai3 »</TD></TR><TR><TD CLASS="quote">nice avatar tougesir
princess mononokee i think i spelt it right</TD></TR></TABLE>
No, in fact you did not. Indeed, you also fucked up the word "spelled".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote">ive been trying to get these bolts for the bumper out but they just wont come out and now there like half way striped. any suggestions, can i just drill them out? or use a bolt extractor?</TD></TR></TABLE>
Impact screwdriver, $20 at Sears. It'll save you many a headache on many a job. Also, feel free to bolt-and-washer those rat bastards afterwards as there's no reason to have those special Honda flat-tops in there as all they do is rust to the core support and make life difficult
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
Word. Replace the screws with a metric bolt. It will save headaches in the future. If you can, put a rubber isolator in there like the stock ones to prevent your bolts from coming loose.
.</TD></TR></TABLE>Word. Replace the screws with a metric bolt. It will save headaches in the future. If you can, put a rubber isolator in there like the stock ones to prevent your bolts from coming loose.
i had this problem. just do this get a drimel or die grinder and cut a grove in the screws and use a flat head to get them out. works like a charm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">Vice grips worked for me! </TD></TR></TABLE>
me too when the screwdriver couldnt hack it on my old eg
before i spent 20 bucks at sears, i tried the vice grips, besides one cut knuckle, they all came out fine, god those sucked.
also, im starting a new topic to show how its coming along
