What causes this?
Ive got an lsvtec in my da and i put a 70mm throttle body on it last night and bored out the intake manifold, and now i can't get my motor to run right. its puttering and smoking white and reeks of coolant or fuel, not sure which. I pulled the plugs and they were all black on the electrodes except for the cylinder closest to the distributor. so i figured they were old and that was part of my problem. So i replaced them with brand new plugs, same issues, and still getting a check engine light. So i pull the plugs again... after starting the motor twice and letting it idle for a brief amount of time each time, these brand new plugs are in the same condition as the ones i pulled earlier, all black except for that one cylinder.... and after pulling the plugs there is a light white smoke coming from those cylinders.
what did i fawk up?
what did i fawk up?
expletive autozone. get a paperclip or something, jump the connector, tell me how many long and how many short blinks there are and i'll tell you what it means.
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">ok, where exactly do i stick the paperclip?</TD></TR></TABLE>
In one of the wire harness's that you stick into the ECU
milkwasabadidea
11
Aug 29, 2011 08:08 PM
gsrboost
Mar 20, 2005 11:27 PM
