installing a front bumper
Old Jan 13, 2006 | 01:48 PM
spazz0nater's Avatar
Default installing a front bumper
So i got in a wreck while back and the front mubper was ripped off. So i have no idea how it goes back on. And now i have a brand new bumper and it has no were to attach to. So im lost. Any guides on the internet on removing the bumper would work too. Just need to see how its all mounted.
Thanks
Old Jan 13, 2006 | 02:05 PM
g-ride-si's Avatar
Default Re: installing a front bumper (spazz0nater)
from what i remember, take out the headlights, filler piece and you should see the mounting bolts for the cover at least.
do you mean the actual steel bumper or the plastic bumper cover(what you see from the ouside)?
Old Jan 13, 2006 | 05:12 PM
Default Re: installing a front bumper (g-ride-si)
well i got in a wreck and it was ripped off the car. I got the headlights and corner lights and filler peice and steel part installed. Just need to figure out how to install the bumper (the plastic part) or bumper cover. Just some pictures of were is was supposed to be mounted previously would work too.
Old Jan 13, 2006 | 05:13 PM
Stunna MIKE's Avatar
The bumber bolts are behind the bumber lights. And in the wheel well.
Old Jan 13, 2006 | 05:20 PM
1989CivicSi's Avatar
Default Re: (Aaron EF9)
Assuming that your bumper support is still intact, and installed on the new bumper...
2 bumper bolts behind each corner light
2 screws at the outer front of each wheel well
2 bolts under the car
Old Jan 13, 2006 | 05:22 PM
Default Re: (1989CivicSi)
so you mount the bumper cover to the support the attached the unit together?
Old Jan 13, 2006 | 05:33 PM
Default Re: (spazz0nater)
so i got this image, its for a 89, is there any difference between the 89 and 90 besides cosmetics?
Old Jan 13, 2006 | 05:36 PM
Sorry I can't help you anymore because I have an 89, but on the 89, you basically have the bumper brackets mounted on the car, the bumper support mounted on the bumper, then you mount the bumper/bumper support as one unit onto the car. Dunno about the 90 + HB's.
Old Jan 13, 2006 | 05:43 PM
thanks i do know the bottom bolt and the side slider ones are the same but just need to know if the other braket is the same. Im pretty sure alot of stuff i needed got ripped off.
fog raw
Dec 26, 2011 04:56 PM
gsrpedro
Feb 28, 2007 08:23 PM
Hybridcrx469
Dec 25, 2004 08:06 PM
91STD
Nov 28, 2004 07:37 AM
