92 Accord electrical trouble
Old Jan 13, 2006 | 09:30 AM
striker369's Avatar
Default 92 Accord electrical trouble
Hi, this is my first post here, so I hope i'm doing everything right.
This week I have purchased a 1992 Honda Accord LX, it's a great running car, but I have no tail light's, no running light's, no dash light's, and no turn signal's, and my hi beam's are on almost all the time, some times it will go to low beam's, but when you turn the car off and restart it, it goes back to hi beams. My headlight's work, and my brake light's work, and my 4 way hazzard light's function properly.
All fuses are good, as well as the bulbs. Some one else has told me that it could be the light switch in the colum, so I am going out after I write this to check it out.
Any idea's or suggestion's would be greatly appriciated This is not my first Honda, and I really love these car's, and really don't want to scrap this one because of electrical GREMLIN'S! LoL
Thanks
Old Jan 13, 2006 | 10:41 AM
djryan's Avatar
Default Re: 92 Accord electrical trouble (striker369)
I'm not sure about your turn signals and headlights, but here is a post that fixed someone else's accord that had the same taillight problem.
https://honda-tech.com/zerothread?id=1477903
Old Jan 13, 2006 | 01:22 PM
striker369's Avatar
Thank's for your reply, I now have tail light's and everything else working accept my signal light's. right now, the driver's side turn signal comes on, but does not turn off or flash, even with the key out of the ignition, and it doesn't matter where you put the turn signal switch. my hazzard light's turn on, but won't flash any more either, unless you pull the small light fuse under the hood, then the hazzard flashes properly, but the turn signal turnes off all togeather. Any other idea's would be greatly appriciated.
Thank's
driftmonk
Nov 18, 2006 05:07 PM
tjd92accord
Dec 9, 2005 03:25 PM
robertm2
May 13, 2005 08:53 PM
