my compression results
Old Jan 13, 2006 | 07:34 AM
fastfu's Avatar
Default my compression results
i need help some in what the results should be as there was never a manual released for the prelude over here in the uk
anyway the results i got were.
218,220,220,218
i know that means i don't have any bad rings because all of the cylinders are pretty close but what should the compression be
Old Jan 13, 2006 | 07:35 AM
PrecisionH23a's Avatar
Default Re: my compression results (fastfu)
It would help if you told us which engine you had.
But either way, your engine sounds fine. Cylinder leakdown tests are the way to go though.
Old Jan 13, 2006 | 07:36 AM
fastfu's Avatar
Default Re: my compression results (PrecisionH23a)
its a H22
Old Jan 13, 2006 | 01:05 PM
InvaderTrax's Avatar
Doesn't matter what engine he has. 220 is wonderful for any F/H series
Old Jan 13, 2006 | 05:13 PM
LudeyKrus's Avatar
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't matter what engine he has. 220 is wonderful for any F/H series</TD></TR></TABLE>
Higher compression, especially on a lower-compression engine, isn't always great.
Old Jan 13, 2006 | 07:47 PM
Rosko's Avatar
those numbers sound right on to me, especially since there is little difference between the 4 cylinders.
Old Jan 13, 2006 | 09:11 PM
vinuneuro's Avatar
Default Re: (LudeyKrus)
Please explain
Old Jan 14, 2006 | 06:09 AM
LudeyKrus's Avatar
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote"> Please explain</TD></TR></TABLE>
Some motors are supposed to have low numbers. If, say, an F22 is registering 270psi across the board, then SOMETHING's a bit overboard; such as carbon buildup. While a little is normal and will raise compression numbers noticeably, a hell of a lot of carbon on the piston crowns is not a great thing.
Old Jan 14, 2006 | 06:56 AM
alkaloidz's Avatar
I don't know if it helps but i just did a compression test on my Jdm h22a and got
235,235,235,235 they were within a point or two. Kind of hard to tell when it goes in increments of 5 on the guage.
Old Jan 14, 2006 | 09:44 AM
SteveoBA8's Avatar
Default Re: (alkaloidz)
MY jdm h22 showed 221,219,220,220, your good to go.
Old Jan 14, 2006 | 10:16 AM
specbb6's Avatar
Default Re: (SteveoBA8)
average (good) numbers.
chuisek9
Sep 9, 2007 11:01 PM
square_1
Sep 15, 2006 02:08 PM
dohcter g
17
Mar 23, 2005 07:47 PM
mjrage
12
May 28, 2004 03:20 PM
92TypeR
Aug 21, 2003 01:51 PM
