91 accord h22 swap
Old Jan 13, 2006 | 05:19 AM
allshowaccord91's Avatar
Default 91 accord h22 swap
my car is being changed from auto to 5spd... where does the clutch master cylinder mount at? im supposed to use all accord mounts correct? what is the box titled "AT CONTROL UNIT" that is mounted right beside my ECU? will there be any drilling/grinding for the 5spd shifter assembly/box?
thanks for (+) input!
Old Jan 13, 2006 | 09:29 AM
wrichards2005's Avatar
Default Re: 91 accord h22 swap (allshowaccord91)
The AT control unit/TCU has to be removed. It tells your car when to shift, and for obvious reasons the car will not be shifting automatically any longer. You can use all the old mounts, but you have to take off the selenoid for the rear mount, I just recommend switching out the mount. BTW have you checked out CB7tuner.com?? There are a bunch of do it yourselfs for 90-93 accords, including the auto to 5 speed swap.
Old Jan 13, 2006 | 01:21 PM
Default Re: 91 accord h22 swap (wrichards2005)
sounds like i need to check out that site...thanks alot!
Old Jan 15, 2006 | 05:50 PM
RidnLow's Avatar
you will find everything you need to know about the swap on http://www.cb7tuner.com everytime i need to find out something i go to that site. just go to the site on go onto the seach option and type in 5 speed conversion! hope it helps u out
dutchman5
Dec 18, 2005 12:13 AM
JBk24crx
Apr 16, 2005 01:35 PM
daidilus
Mar 15, 2005 10:38 PM
azzinine1
Jul 13, 2004 04:52 AM
Civichatch2k
Aug 9, 2003 04:55 PM
