HELP !!! w/ JDM Integra DC2 98 Spec. Type R 23mm Rear Sway Bar !
Old Jan 12, 2006 | 09:58 PM
smellerd's Avatar
Default HELP !!! w/ JDM Integra DC2 98 Spec. Type R 23mm Rear Sway Bar !
Hi all, I have a question for the many extremely knowledgeable honda wizz's. I need to know if a JDM Integra DC2 98 Spec. Type R 23mm Rear Sway Bar will work on a 96 civic 4dr. I know I might have to do some work to get it to fit but I just wanted some input before I buy it from a friend. He bought it a year ago for an integra but didn't use it and since he owes me $ he wants to work a swap. Any help with this would be greatly appreciated. Thanks in advance, D...
Old Jan 13, 2006 | 04:29 AM
smellerd's Avatar
Nobody???
Old Jan 13, 2006 | 04:36 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (smellerd)
What exactly do you want to know? I've got the itr 26mm bar. I can help.
Old Jan 13, 2006 | 04:38 AM
gftgrill's Avatar
it should work. you'll need to get endlinks, the subframe brackets as well as look into something the beaks subframe reinforcement kit. You'll also have to do some drilling to get the brackets to mount to the subframe.
Old Jan 13, 2006 | 04:44 AM
smellerd's Avatar
Another quick question: Will a rear sway bar from a 1996 integra work on the back of a 96 civic 4dr???
Old Jan 13, 2006 | 07:57 AM
crimsonv4mpire's Avatar
Default Re: HELP !!! w/ JDM Integra DC2 98 Spec. Type R 23mm Rear Sway Bar ! (smellerd)
subframe death! i recomend the 19mm
Old Jan 13, 2006 | 08:07 AM
iLOVEmyEMone's Avatar
http://www.beaksproducts.com/S...t.htm
http://www.beaksproducts.com/E...s.htm
use that and u should be good.
Motkaluk
Suspension & Brakes
Mar 16, 2014 12:16 PM
Uncle Jesse
Jun 11, 2007 08:45 AM
HB-II
Suspension & Brakes
Dec 21, 2006 05:12 PM
cvccjdm
Sep 29, 2004 01:14 PM
B18Redline
Jun 26, 2004 10:41 PM
