In over my freakin head / Winshield replacement
Old Jan 12, 2006 | 09:25 PM
CRXual's Avatar
Default In over my freakin head / Winshield replacement
Ok so I have just started with the most stripped tub I could find but I am finding that I know nothing about winshield replacement. I got this tub and the windshield was toast so I broke out the rest of it to find that around the edges, the glass chunks hold on really well to this rubber strip that I have found also holds on really well to the sill. Is there a good way to remove all of the above? I have been working at it with a screwdriver but it seems alot like pissing in the wind. Any Ideas or info would be welcome.
Old Jan 12, 2006 | 09:36 PM
g-ride-si's Avatar
use a wire band(speaker wire with the plastic peeled off) and get it under the weather stripping/ window seal and pull that bitch out.
warning: wear gloves
Old Jan 12, 2006 | 09:53 PM
~Aj~'s Avatar
Default Re: (g-ride-si)
Also let the car sit in the sun all day to soften up the weatherstip. Use a heat gun/hairdryer to help even more.
Old Jan 12, 2006 | 10:46 PM
CRXual's Avatar
Default Re: (~Aj~)
Right on, its been raining here for 3 weeks straight so sunlight is out of the question but I will try the speakerwire trick. sounds like it would help.
thanks
Mike
Stryker
Paint and Body
10
Dec 13, 2009 05:02 PM
ScrapinSi
Nov 7, 2009 04:48 PM
importfanatic17
Jan 19, 2007 01:43 PM
d16efsedan
Feb 23, 2006 09:39 PM
swtcivic93
Jun 18, 2002 10:12 PM
