Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout
Old Jan 12, 2006 | 08:35 PM
hotimportcrx's Avatar
Default Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout
I want to hear some opinions!!!!
Street driven Ls vtec turbo (450whp) on high boost (300whp on low)....what exhaust do you guys think should be on it...
A full 3 inch exhaust from the downpipe back
or
3 inch downpipe w/ 2.5 inch exhaust (but a 3 inch cutout after downpipe)
Old Jan 12, 2006 | 08:36 PM
Squallie's Avatar
Default Re: Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout (hotimportcrx)
if im not mistaken the 2.5 would offer more torque? not sure. somebody correct me if im wrong
Old Jan 12, 2006 | 08:58 PM
dohcVTECeg2's Avatar
Default Re: Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout (Squallie)
3 inch all the way.
Old Jan 12, 2006 | 09:20 PM
sicky's Avatar
grammer nawzi
Default Re: Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout (dohcVTECeg2)
go with 2.5. You'll have more pull in the higher gears.
Old Jan 12, 2006 | 09:23 PM
eXcelonTypeR's Avatar
Default Re: Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout (sicky)
I say go with both setups, funds permitting. Since you have 2 boost levels I thinking having the smaller exhaust for the street would do you just fine. And have the 3 inch for track(assuming high boost is for there) runs so the beast can breathe . thats my .02 cents
Old Jan 12, 2006 | 09:28 PM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">go with 2.5. You'll have more pull in the higher gears.</TD></TR></TABLE>
where did you come up w/ that???
go 3inch (at least) turbo back!!!
Old Jan 13, 2006 | 11:04 AM
Default Re: Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout (12SEC CIV)
thanks for the feedback ! bump for some more
Old Jan 13, 2006 | 11:23 AM
ChewiSi's Avatar
3 inch for better spool but if you can't afford that then i guess you could do a 2.5 inch with a e-cutout but you better have two different tunes for the 2.5 inch @ WOT and the e-cutout @ WOT.
Old Jan 13, 2006 | 11:56 AM
alleyezonme's Avatar
Default Re: (ChewiSi)
3 inch, i always thought with a turbo the bigger the better right??
Old Jan 13, 2006 | 12:30 PM
Everyones Hero's Avatar
Default Re: (alleyezonme)
I'd use the 2.5" w/ 3" ECO. With the 3" cutout you will have zero restrictions after your downpipe because the exhaust will be exiting the system as opposed to a full 3" system that requires the exhaust gas to go from your turbo, through your cat (or testpipe), ect, ect.
Especially being turbo you want as little exhaust restrictions as possible, especially since you're already putting down good numbers.
Is the car tracked at all?
Old Jan 13, 2006 | 04:14 PM
platinum00's Avatar
Default Re: (Everyones Hero)
you want 3 inch all the way back.
your going to get a quicker spool and pick up some hp/tq.
platinum.
Old Jan 13, 2006 | 04:47 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">I'd use the 2.5" w/ 3" ECO. With the 3" cutout you will have zero restrictions after your downpipe because the exhaust will be exiting the system as opposed to a full 3" system that requires the exhaust gas to go from your turbo, through your cat (or testpipe), ect, ect.
Is the car tracked at all?</TD></TR></TABLE>
...I don't think that was one of his options? 3" DP, 2.5" Piping, 3" tip is what he was talking about.
3" through everything, no question.
Old Jan 13, 2006 | 09:16 PM
Default Re: (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">...I don't think that was one of his options? 3" DP, 2.5" Piping, 3" tip is what he was talking about.
3" through everything, no question. </TD></TR></TABLE>
I just re-read his post. His options are 3" turbo back or 3" DP, 3" Cutout, 2.5" exhuast.
I still say go with the 2.5" for the little bit of extra torque for regular driving and the cutout for when you get on it.
Old Jan 13, 2006 | 09:31 PM
yea im still unsure what im going to do...probably a 3 inch but wanted to see what everyone thought...because a 3 inch is loud and ill get pulled over 100 times a day
Old Jan 13, 2006 | 09:41 PM
11SEC CIV's Avatar
Default Re: (hotimportcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">because a 3 inch is loud and ill get pulled over 100 times a day</TD></TR></TABLE>
is your car currently turbo or have you been in a turbo car....most turbo cars are quieter (much quieter) then n/a cars...the manifold/turbo acts like another muffler
Old Jan 13, 2006 | 09:47 PM
sicky's Avatar
grammer nawzi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">where did you come up w/ that???
go 3inch (at least) turbo back!!! </TD></TR></TABLE>
That was completely sarcastic. Sorry for not noting so.
hialeahzbg
Mar 2, 2010 11:22 AM
n0pinitr0us
Dec 23, 2004 09:43 AM
Derek14
Mar 23, 2004 09:10 AM
b18cTurbo
Feb 26, 2002 06:41 PM
