Car won't start. Bad ignition switch?
Old Jan 12, 2006 | 08:30 PM
GhostBB6's Avatar
Default Car won't start. Bad ignition switch?
Car quit while I was driving on the hwy to work. No hesitation at all, just dies. I got it retarted once but died rather quick and hasn't restarted since. The thing is the dash is also dead. None of the dash lights come on when the key is turned. Absolutely nothing. I've checked on the fuses and they're all fine. Power windows, sun roof, clock doesn't work either. Starter works but there is no ignition. Battery should be fine as it was only replaced last year. Is a bad ignition switch the cause?
Old Jan 13, 2006 | 12:02 AM
i_kick_turtles's Avatar
Default Re: Car won't start. Bad ignition switch? (GhostBB6)
I think you're right, bad ignition switch. I'm assuming you checked to make sure the battery is charged.
Old Jan 13, 2006 | 04:47 AM
kulrevon's Avatar
Default Re: Car won't start. Bad ignition switch? (I R Tylor)
I believe there waas a recall on the 5th gen ignition switch I could be completely wrong because I have a 4th gen.
Honda knowledge
Apr 18, 2015 08:00 PM
91-lsvtecsi
Mar 4, 2012 02:47 PM
Unphzd
Jun 16, 2011 09:57 AM
Honda Virgin
Jun 2, 2004 12:34 PM
JToolz
Feb 15, 2004 06:56 PM
