Z6 crx injector
Old Jan 12, 2006 | 08:19 PM
killa rex's Avatar
Default Z6 crx injector
i was wondering if anyone have information about the resistor box.. i've converted over to obd 1...does anyone know how to eliminate the resistor box??
Old Jan 12, 2006 | 08:59 PM
crxnj's Avatar
Default Re: Z6 crx injector (xmunxjai648)
Just get some saturated injectors and connect the wires that go into the resisor box..
You can just keep it how it is now though ,,with the resistor box and peak/hold injectors
Old Jan 24, 2006 | 11:35 PM
killa rex's Avatar
Default Re: Z6 crx injector (Mr.speaker)
well..i'm using the obd1 injectors with the resistor box...but aren't obd1 injectors saturated?? or is it peak'n'hold??
Old Jan 25, 2006 | 12:03 AM
Nerologic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xmunxjai648 &raquo;</TD></TR><TR><TD CLASS="quote">well..i'm using the obd1 injectors with the resistor box...but aren't obd1 injectors saturated?? or is it peak'n'hold??</TD></TR></TABLE>
u need to take the resistor box out of the mix, or run obd0 injectors...
Old Jan 25, 2006 | 12:56 AM
DEIVIONCRX's Avatar
Default Re: Z6 crx injector (Nerologic)
OBD0 and 2 injectors require the Resistor box
the Obd1 injectors do not
i dont rember which are Saturated and Peak and Hold
Old Jan 25, 2006 | 01:55 AM
jisu009's Avatar
Default Re: Z6 crx injector (DEIVIONCRX)
non OBD is Peak and hold, OBD 1 is Saturated.
Old Jan 25, 2006 | 02:54 AM
crxnj's Avatar
Default Re: Z6 crx injector (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">non OBD is Peak and hold, OBD 1 is Saturated.</TD></TR></TABLE>
Yeah for the most part but there is also some obd1 preludes that have peak and hold injectors with resistor box.
Randysi
Apr 4, 2012 10:17 AM
pinecone
Apr 25, 2006 06:41 AM
drSquish
Jan 19, 2006 01:54 PM
e jay one
Aug 6, 2005 02:48 PM
