what would the symptoms be of a messed up throw out bearing or a pilot bearing?
Old Jan 12, 2006 | 07:48 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default what would the symptoms be of a messed up throw out bearing or a pilot bearing?
i just have a problem and i THINK its one of these, so what would i should be experiencing if it were to be a messed up throw out bearing. and then what else should i be experiencing if its the pilot bearing that is messed up?
Old Jan 12, 2006 | 08:05 PM
jdmcars.com's Avatar
Default Re: what would the symptoms be of a messed up throw out bearing or a pilot bearing? (candy eg)
Vibration. Maybe a different feel in the pedal when engaging the clutch -and most of the time -SOUND. Normally if either are worn badly -they will make a noise.
Old Jan 12, 2006 | 08:48 PM
candy eg's Avatar
Default Re: what would the symptoms be of a messed up throw out bearing or a pilot bearing? (jdmcars.com)
so should i buy both before taking off my tranny? how much do they usually run for?
civic ef
May 29, 2012 01:02 AM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
Eklsv-t
Aug 28, 2008 10:52 AM
Aron Parsons
Mar 6, 2006 09:18 PM
