weird bubbly water noise inder my dash when i rev to 2-4000
Old Jan 12, 2006 | 06:42 PM
JDM_EK_JOE's Avatar
Default weird bubbly water noise inder my dash when i rev to 2-4000
k when i start the car i hear something bubbling under my driver side dash coming from the hood close to the firewall. I dont know what it is and when i drive for like 30 min it gets quieter. It usually happens around 2-4000 rpm??
Old Jan 12, 2006 | 06:56 PM
Speed--Freak's Avatar
You are low on coolant or have lots of air in the system. It gets quieter as it heats up because the fluid is expanding and pushes some of the air out.
Old Jan 12, 2006 | 07:06 PM
JDM_EK_JOE's Avatar
Default Re: (Speed--Freak)
How can I get that air out of the system??
Rob.'s Avatar
Default Re: weird bubbly water noise inder my dash when i rev to 2-4000 (91Civic_Joe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91Civic_Joe &raquo;</TD></TR><TR><TD CLASS="quote">k when i start the car i hear something bubbling under my driver side dash coming from the hood close to the firewall. I dont know what it is and when i drive for like 30 min it gets quieter. It usually happens around 2-4000 rpm??</TD></TR></TABLE>
no idea man
Old Jan 12, 2006 | 07:07 PM
lodo1's Avatar
Default Re: (91Civic_Joe)
bleed your coolant with the heater on
Old Jan 12, 2006 | 07:08 PM
JDM_EK_JOE's Avatar
Default Re: weird bubbly water noise inder my dash when i rev to 2-4000 (Rob.)
How can i bleed the coolant??
Old Jan 12, 2006 | 07:13 PM
You should first confirm that it is low.
All you need to do from there is fill it up and make sure there is some in the overflow bottle. After a couple heat cycles it will bleed it self.
Old Jan 12, 2006 | 08:45 PM
JDM_EK_JOE's Avatar
imma try first thing tomorrow and let you guys know what happened
Old Jan 12, 2006 | 09:04 PM
bspeed's Avatar
It can also be the pilot and throw-out bearing in your clutch assy.
Whydid
Dec 9, 2015 04:13 PM
alpine87
Honda Civic (2001 - 2005)
Dec 13, 2014 06:09 PM
Captain_Fook
Jul 1, 2014 05:23 AM
swapdohc
Jul 14, 2005 11:13 AM
nerdish
Jul 9, 2001 02:36 PM
