kamikaze header, good or bad for my engine?
Old Jan 12, 2006 | 06:05 PM
c0nspire's Avatar
Default kamikaze header, good or bad for my engine?
Hi, right now i am runnign a hedman chikara on my engine and wondering if a kamikaze would be a better option. The chikara header i have was designed to produce torque, but only creats power up to 6000rpm, i have a 9000 rpm redline.
Just wondering if the new kamikaze header for the sohc would be an appropriate match? The stats say that its suppost to be used on a supercharged application. The kamikaze has a 2.5" outlet size which is what my exhaust is from the cat back.
here is my setup
jdm vtec zc
eagle rods
cometic headgasket (turbo application)
endyn rollerwave pistons (turbo application)
crower stage2 turbo cam
edelbrock cam gear
endyn supplied/work:
endyn oversized springs
oversized valves
port and polish
high flow oilpump
fidanza alum. flywheel
centerforce2 clutch
arp studs + bolts
60mm tb
edelbrock performerX IM
short ram air
chikara hedman header
2.5" mandrel (magnaflow cat and 2 mufflers)
rc injectors
str fuel rail
b&m fpr
liquid filled gauge for fp
hondata s100b in a p28
msd 6al
magnacor spark plug wires
ngk plugs
all balanced, honda oem berrings
dohc dc tranny, quaife, 4.43 fd
plzbeleiveit
28
Jun 7, 2008 05:10 PM
c0nspire
Jan 13, 2006 02:31 PM
DANG YO
Sep 22, 2005 11:33 AM
..::91TEG-G2::..
Jan 29, 2004 04:40 PM
