draining 96 lx auto tranny
Old Jan 12, 2006 | 04:16 PM
sony224422's Avatar
Default draining 96 lx auto tranny
is the nut on the bottom of the tranny, towards the passengers side thats bigger than all of them the drain nut? I need to drain all the fluid, its never been done and its got 104k on it. can someone tell me whats the best way to do this?
Old Jan 12, 2006 | 04:33 PM
OldTopTech's Avatar
Default Re: draining 96 lx auto tranny (sony224422)
No,
It's the round headed drain plug on the right side. A 3/8ths rachet will fit the plug.
Old Jan 12, 2006 | 06:21 PM
sony224422's Avatar
Default Re: draining 96 lx auto tranny (OldTopTech)
so its facing the oil pan? and when i take it out how much fluid will come out?
Old Jan 12, 2006 | 06:39 PM
HandoEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">I need to drain all the fluid, its never been done and its got 104k on it. </TD></TR></TABLE>
Old Jan 12, 2006 | 06:45 PM
BLKFLSH's Avatar
Probably not more than 4 quarts. A lot of it stays in the trans. Look in your manual for exact capacities. If the fluid is real dirty, you may want to change it three times, with a 15-20 mile drive in between each change (it's what is called a trans flush). Use only Honda ATF-Z1, it costs about $4.00 a quart. Will cost you about $40.00 to do a flush.
Old Jan 12, 2006 | 06:58 PM
sony224422's Avatar
Default Re: draining 96 lx auto tranny (BLKFLSH)
thanks. $40 is alot cheaper than a new tranny. will this stop the kinda hard shifting?
Old Jan 12, 2006 | 07:01 PM
BLKFLSH's Avatar
It's definitely worth a shot.
Old Jan 12, 2006 | 08:40 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">so its facing the oil pan? and when i take it out how much fluid will come out?</TD></TR></TABLE>
NO it's not facing the oil pan..it's a round head bolt with a 3/8" square hole in the center of it, facing toward the passenger side; amazingly enough a 3/8" ratchet will fit right into the drain plug hole.
Refill with 3 quarts of honda fluid.
Old Jan 13, 2006 | 05:33 AM
sony224422's Avatar
Default Re: draining 96 lx auto tranny (hondadude)
yeah thanks, thats what i thought it was.
alexdc03
Mar 26, 2012 04:40 PM
sony224422
Mar 31, 2006 06:56 AM
garrybloom
Dec 12, 2005 04:16 PM
rex03
Sep 30, 2003 09:30 PM
