How Much Tire.....
Old Jan 12, 2006 | 04:03 PM
kdawgy2k1's Avatar
Default How Much Tire.....
Hey room wassup??? i have a 91 DA with built Turbo b16a currnet making 325+ whp... i am currently runnin on a set of 205/50/15 Dunlop SP 5000 and i can smoke them like nothing when boost in the picture... i was wonering if a 215 or BFG 225 will fit on a set of GSR Fat 5 wheels thanks alot
Old Jan 12, 2006 | 04:13 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How Much Tire..... (kdawgy2k1)
Your problem isn't the SIZE of tire. It's the TYPE of tire. The Dunlop SP5000 is an all-season tire, and not a particularly good all-season tire at that. At moderate to warm temperatures (when there's no snow or frigid cold), all-season tires don't perform very well, not even as well as inexpensive summer tires. So you really need to get BETTER tires, not WIDER tires.
For your car, on 15" wheels, the proper tire sizes are either 195/55-15 (1.0 percent larger diameter than stock) or 205/50-15 (0.6 percent smaller). Anything larger will probably rub on the wheel wells.
There are a lot of tires available in those sizes, particularly 205/50-15. For a high-horsepower application, assuming you care only about dry traction, you don't mind if the tires don't last all that long (say, 9-12K miles), you don't care how much they cost, and you're not driving in winter conditions, then I recommend you get the Falken Azenis RT-615 in 205/50-15, which is the right size for the 15x6 "fat fives" on your car. This is the tire with the highest dry traction you'll find anywhere in a street tire. They're $78/tire at Vulcan Tire.
Old Jan 12, 2006 | 06:28 PM
BrokenRex
Guest
Posts: n/a
sry 2 jack this, but first of all i have 205/45/16, my fronts went bald(hankook k106), so i ordered 2 dunlop sp sports, to replace the front. My question is; is it bad having 45 instead of 50/55 ? , and also having 2 different types of tires ? ? and wat does v-rated and 200 treadware mean . . . . im assuming the tires i just bought wont last long at all.
Old Jan 12, 2006 | 06:45 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How Much Tire..... (BrokenRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenRex &raquo;</TD></TR><TR><TD CLASS="quote">i have 205/45/16, my fronts went bald(hankook k106), so i ordered 2 dunlop sp sports, to replace the front. My question is; is it bad having 45 instead of 50/55 ? , and also having 2 different types of tires ? ?</TD></TR></TABLE>
It's NOT a good idea to have different sized tires (unless your car was designed for that) and it's NOT a good idea to have two different types of tires. That makes the handling very unpredictable. Your car might oversteer in some conditions, understeer in others, etc. NOT a good idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenRex &raquo;</TD></TR><TR><TD CLASS="quote">wat does v-rated and 200 treadware mean . . . . im assuming the tires i just bought wont last long at all.</TD></TR></TABLE>
You can read all about tire sidewall ratings on the Tire Rack website; click here. Then click on Speed Rating for the V, UTQG for treadwear, etc.
Jswike
Jan 14, 2013 04:15 AM
Outlaw-Hondaz
Jun 8, 2011 12:00 PM
EFsSuck
Oct 14, 2009 05:40 PM
uncleben
Jan 18, 2006 08:23 PM
JDM Factor
Jun 7, 2005 01:28 AM
