Welding flange to stock mani
Old Jan 12, 2006 | 03:45 PM
02slpr's Avatar
Default Welding flange to stock mani
I drive a hyundai and it would be easier for me to just get a turbo flange welded on my stock manifold, only problem is its cast. Does anyone have any pics of welded cast manifolds and perhaps some hints. Any help would be greatly appreciated. The turbo is going to be a 14b since my engine is so small and weak lol. Thank you!
Old Jan 12, 2006 | 04:20 PM
k24em2's Avatar
Default Re: Welding flange to stock mani (02slpr)
Take it to someone who knows cast iron.
Old Jan 12, 2006 | 08:38 PM
eg crunkmonster's Avatar
Default Re: Welding flange to stock mani (k24em2)
get an adapter plate made....that sounds like a more reliable choice
Old Jan 13, 2006 | 04:42 AM
02slpr's Avatar
Default Re: Welding flange to stock mani (eg crunkmonster)
there is no flange to apply the adapter plate to, its kinda like a focus manifold if you have ever seen one, it has a cataltic converter welded or formed into it.
Old Jan 13, 2006 | 07:57 AM
90DALS's Avatar
it can be done. find someone local that will do it for you. i have welded cast before.
Old Jan 13, 2006 | 07:58 AM
beepy's Avatar
Which Hyundai? There may be manifolds available for it from Kuk performance in Korea. Talk to Bill Hurlin at bhurlin@kfxperformance.com.
Otherwise get a log manifold made. The hardest part is getting the head flange machined. Send a gasket to James at BMC racing (pm BmCRace.com) and he can make you some.
BTW, the cat is stir welded onto the cast iron manifold. If you simply cut the cat off below the weld, you can weld a flange to it easily because it is stainless steel from that point on. The problem is that the turbo will be too low to make the oil drain on the turbo good.
Old Jan 13, 2006 | 09:42 AM
VRD^don's Avatar
i wouldnt do it..you'll run in to problems with fitting the turbo in nicely, and dp issues....it'll be alot harder to do a custom dp with it...just buy one..there should be manifolds out there for your application..
Old Jan 14, 2006 | 09:13 AM
Si Shane's Avatar
Default Re: Welding flange to stock mani (option_2)
In the sponser section send some dude an exhaust manifold gasket (which you can buy) and he will cut you a flange for like 50 bucks or whatever he charges.
nitroice40
Welding / Fabrication
Apr 6, 2006 03:11 PM
RACEPAK
May 1, 2005 03:06 PM
JDM EJ1 95
Aug 18, 2004 04:45 PM
Bailhatch
Jan 12, 2004 08:56 PM
W.Zero
Mar 2, 2003 09:48 PM
