CRX does not start in the morning
Old Jan 12, 2006 | 02:34 PM
Shaminda's Avatar
Default CRX does not start in the morning
My CRX does not start every morining. Distributer is fine and motor turns fine but does not start. A "toc toc ..." sound comes occationsly when trying to start. Usually starts after trying for about 10 times. After that it starts perfectly fine just with a single click and no "toc toc " sound.
Checked the spark and they look fine.
Please help.
Old Jan 12, 2006 | 02:44 PM
1989CivicSi's Avatar
Default Re: CRX does not start in the morning (Shaminda)
Sounds like your starter is going. Rebuild/replacement time?
Old Jan 12, 2006 | 03:00 PM
VtecSyndrome's Avatar
Default Re: CRX does not start in the morning (1989CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your starter is going. Rebuild/replacement time? </TD></TR></TABLE>
Yep, as long as your solenoid is still good and the starter is Nippon Denso then you can rebuild it. About 15 mins to 1/2 hours time depending on tools available
Old Jan 13, 2006 | 04:42 AM
Shaminda's Avatar
Thanks,
But starter turns fine and motor turns well everytime I try to start. In fact after a painful start, car starts fine every time unless it is stopped for 4-5 hours.
Old Jan 13, 2006 | 07:48 AM
Twilight's Avatar
She is still sleeping.
Old Jan 13, 2006 | 10:29 AM
CrX gUy's Avatar
Default Re: CRX does not start in the morning (Twilight)
Check your EAC or EACV valve i have the same problem on my 90 si
VM 2
Mar 17, 2009 04:12 AM
pepper
Sep 21, 2007 07:27 PM
Speedingcivic
Jul 5, 2007 07:55 AM
oldschoolfreak
Jan 16, 2005 08:25 PM
fsck3r
10
Aug 5, 2003 05:43 PM
