itr upgrade question?????
Old Jan 12, 2006 | 10:27 AM
jc@douglas's Avatar
Default itr upgrade question?????
on my 01 itr i have an intake, n1 cat back, dc header, and a race cat, if i did ferrea valve springs and retainers on stock cams what rpm would i be safe reving too??????? is 9k asking to much of the stock bottom
Old Jan 12, 2006 | 10:34 AM
citrus3000psi's Avatar
Default Re: itr upgrade question????? (jc@douglas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc@douglas &raquo;</TD></TR><TR><TD CLASS="quote">on my 01 itr i have an intake, n1 cat back, dc header, and a race cat, if i did ferrea valve springs and retainers on stock cams what rpm would i be safe reving too??????? is 9k asking to much of the stock bottom</TD></TR></TABLE>
It is safe to go to 9k...but with stock cams there isn't as much as a benifit.
Old Jan 12, 2006 | 10:48 AM
92TypeR's Avatar
FSAE
Default Re: itr upgrade question????? (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">It is safe to go to 9k...but with stock cams there isn't as much as a benifit.</TD></TR></TABLE>
^ What he said.
If Honda made power to 9000 RPM's, you would see a 9000 RPM fuel cut, not 8500. You can balance your crankshaft and rotating assembly, install valvesprings and retainers, and take the motor to 10,000 RPM's, but what is the point when after 8500 you are accelerating slower than you would be in the next gear at a better point in the RPM band.
If you installed some cams that made power to 9000 RPM's, it would make a lot of sense to take the motor that high. Otherwise, you are just increasing the wear on the motor and increasing the risk of something going wrong.
Old Jan 12, 2006 | 11:06 AM
jc@douglas's Avatar
Default Re: itr upgrade question????? (92TypeR)
well i ordered a jackson racing supercharger also sorry i should have thrown that out first, they say to use stock cams for the most power.....hmmm maybe i should not even play with it
faSHOwidIT
Apr 5, 2007 07:42 PM
CaseBone
May 22, 2006 01:26 AM
VTEC Visions
10
May 8, 2005 10:19 AM
jdm.ej
May 4, 2004 05:17 AM
gooknom
Jan 26, 2004 02:18 PM
