***94 prelude si*** MAIN RELAY LOCATION??????
Old Jan 12, 2006 | 02:37 AM
bb6_lude's Avatar
Default ***94 prelude si*** MAIN RELAY LOCATION??????
where can i find the main relays to my prelude...im pretty sure its under the dash on the drivers side, but my fuse box doesnt have the cover so i dont know which ones which.
anyone have any pics onf their fuse box...or pics of the fuse box diagram so i can get an idea of what im looking at?
maybe some can be nice enough to maybe go take a pic of it in their car right now...i really need this please ive looked all over for the fuse box cover but cant find one or a picture of one.
PLEASE HELP!
Old Jan 12, 2006 | 05:40 AM
kulrevon's Avatar
Default Re: ***94 prelude si*** MAIN RELAY LOCATION?????? (i_heart_EG)
its not in the fuse box.
It is in that area though. it should be bolted up there. higher up and more towards the drivers door.
it looks like this
Old Jan 12, 2006 | 06:55 AM
Hawkze_2.3's Avatar
Yeah, it's literally right under the top of the dash behind the steering wheel and a bit to the left. It has a brown plug with thicker wires coming out of it...
Old Jan 12, 2006 | 10:30 AM
bb6_lude's Avatar
Default Re: ***94 prelude si*** MAIN RELAY LOCATION?????? (kulrevon)
thanx guys...im goin to go check into it in a little bit.
Old Jan 12, 2006 | 01:38 PM
pprowler6's Avatar
when u find it have fun getting it unbolted, its a royal pain in the ***
Old Jan 12, 2006 | 03:00 PM
SnlpeR's Avatar
i couldnt find the bolt either...
so i just unclipped the inner part of the main relay from the housing
Old Jan 12, 2006 | 04:48 PM
SteveoBA8's Avatar
Default Re: (SnlpeR)
Not a lude but you get the idea.
Check out this site. http://techauto.te.funpic.org/mainrelay.php
Old Jan 12, 2006 | 06:16 PM
prelude72569858's Avatar
Default Re: (SteveoBA8)
pull the gauges out to get it unbolted easy
Old Jan 12, 2006 | 06:18 PM
bb6_lude's Avatar
Default Re: ***94 prelude si*** MAIN RELAY LOCATION?????? (silverlude15)
damn...this sux. looks like i have a royal pain in the *** on my hands. but hopefully ill get it done ok. i think ill just buy a new main relay instead of trying to solder the one in there.
but do you think thats the only think it could be? most of the time it only starts when it is cold outside...other than that it just stutters to start.
Old Jan 12, 2006 | 09:46 PM
AdReNaLiN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">i couldnt find the bolt either...
so i just unclipped the inner part of the main relay from the housing</TD></TR></TABLE>
I did the same as you Sniper - I just unclipped the inner and pulled her out - soldered and refitted - was far easier than trying to get a spanner onto that bolt...
Old Jan 12, 2006 | 11:10 PM
SKDRCR's Avatar
Default Re: (AdReNaLiN)
I just left the old one in there, disconnected the wire connector from it and
reconnected it to the new one and taped it up under the dash.
It can be done in less than a minute.
Old Jan 13, 2006 | 12:01 AM
red92si's Avatar
Just an FYI, but you can also use an Accord Main Relay if your Prelude one is kaput. Getting to the main relay is really not a pain.
Old Jan 13, 2006 | 02:32 AM
bb6_lude's Avatar
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">I just left the old one in there, disconnected the wire connector from it and
It can be done in less than a minute.</TD></TR></TABLE>
lmao nice...that seems way easier than unbolting the old one and putting the new one in.
Old Jan 13, 2006 | 02:34 AM
bb6_lude's Avatar
THANKS FOR THE HELP GUYS!!!!
i really appreciate it!
Old Jan 13, 2006 | 06:05 AM
wstef's Avatar
Default Re: (i_heart_EG)
Here it is grey box on the left of the steering column support:
JdmJah
Jan 8, 2013 10:25 AM
O2DAB05
Jul 10, 2009 06:11 AM
bb6_lude
Jan 23, 2006 07:09 AM
SexyAzNMami
10
Nov 11, 2004 08:20 PM
ef civic
24
Dec 9, 2002 10:01 PM
